0 Replies Latest reply: May 11, 2014 2:40 PM by smiller@callcenters24x7.c RSS
    Windows firewall configuration
    smiller@callcenters24x7.c Community Member
      What steps need to be taken with the firewall to permit access in the LAN to the development server running Cold Fusion's built-in web server?  Simply opening port 80 doesn't seem to be sufficient; by default, Windows 2008 Server R2 is still blocking the programs themselves.  Pasted below is one example, from a block notification, but I need a complete list so that I can be sure I've permitted access to everything that's needed.  Even though the access is just from within the LAN, for testing purposes (at this time), I still like to keep the firewall running as a best practice.
      Cheers,
      Shane
      Windows Firewall was unable to notify the user that it blocked an application from accepting incoming connections on the network.
      Reason:        The application is a system service
      Application Path:    C:\coldfusion11\cfusion\db\slserver54\bin\swagent.exe
      IP Version:    IPv4
      Protocol:    TCP
      Port:        20003
      Process Id:    1444
      User:        SYSTEM
