1. Re: homesite 5.5 resource window will not dock
Martin Jucker May 21, 2007 7:43 AM (in response to borlak)I remember I have had this problem too a while ago. As far as I know you have to fiddle with the registry - but maybe someone has a better solution. I can't see a button to attach a file here, so I show my registry-settings directly here - I hope this helps
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking]
"DockPanelLeft"="211"
"DockPanelRight"="52"
"DockPanelTop"="80"
"DockPanelBottom"="62"
[HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\AllaireTabDockForm0]
"Visible"="1"
"AlwaysOnTop"="1"
"Position"="3,15,205,730"
"Floating"="0"
"DockHost"="DockPanel_Left"
"DockTab"="1"
"ActivePage"="0"
[HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockHelp]
"Visible"="1"
"AlwaysOnTop"="1"
"Position"="0,0,197,694"
"Floating"="0"
"DockHost"="AllaireTabDockForm0"
"PageIndex"="4"
"DockTab"="0"
[HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockLocalFiles]
"Visible"="1"
"AlwaysOnTop"="1"
"Floating"="0"
"PageIndex"="0"
"DockTab"="0"
[HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockProjects]
"Visible"="1"
"AlwaysOnTop"="1"
"Floating"="0"
"PageIndex"="1"
"DockTab"="0"
[HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockSiteView]
"Visible"="1"
"AlwaysOnTop"="1"
"Position"="0,0,208,568"
"Floating"="0"
"PageIndex"="2"
"DockTab"="0"
[HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockSnippets]
"Visible"="1"
"AlwaysOnTop"="1"
"Floating"="0"
"PageIndex"="3"
"DockTab"="0"
[HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockTagInspector]
"Visible"="1"
"AlwaysOnTop"="1"
"Position"="0,0,227,568"
"Floating"="0"
"PageIndex"="5"
"DockTab"="0" -
2. Re: homesite 5.5 resource window will not dock
JeffW Jun 1, 2007 10:54 AM (in response to borlak)see also my faq on this for how to redock it.
Tip: Re-Docking Resource Windows
http://www.wilk4.com/asp4hs/tips.htm#redocking_resource_windows -
3. Re: homesite 5.5 resource window will not dock
charkins51 Jun 19, 2007 1:10 PM (in response to JeffW)Thank you, thank you. This little exercise (before I found your excellent post) wasted the better part of half a day. I'll definitely be keeping your site as a bookmark for future reference. Thanks again!
Carol -
4. Re: homesite 5.5 resource window will not dock
pgael Aug 24, 2007 2:40 PM (in response to borlak)I'm having a similar problem with my Snippets window in Homesite 5. It used to dock in the resource window, but the snippets tab has now disappeared from the resource window and I cannot find a way to redock my snippets. The solution mentioned here will not work for me because there is no files list section in the snippets window, nor can I adjust the window to make a files list section appear.
Any help you can provide would be greatly appreciated. This has been driving me crazy. :) Thanks! -
5. Re: homesite 5.5 resource window will not dock
borlak Aug 25, 2007 6:59 AM (in response to pgael)did you try the registry hack the above guy mentioned?
I actually just got used to pressing F9 to bring up the resource window :P I found I liked having the extra space anyway.. but, looking at the registry settings he put up, those look quite promising -
6. Re: homesite 5.5 resource window will not dock
JeffW Oct 5, 2010 1:35 PM (in response to borlak)btw, I just had this problem myself. Homesite crashed once then when I restarted everything was undocked.
Even though I knew from my own notes how to redock most of them, the snippets tab was a bugger.
Oddly enough, *sometiems* the snippets tab will give you that move-to menu option to let you re-dock, but not always. Seems related to the order you redock tabs. Perhaps you just need to not have it be last.
Anyway, I had to add in some of those registry values (while HomeSite was closed) to redock it.
I'll add those details to my faq as soon as I get chance.
One note to add to that, it seems that the DockHost value for the tabs is sometimes slightly different.
Mine is:
"DockHost"="AllaireTabDockForm1"
If you look at the keys under
you'll see that one of them is something like
AllaireTabDockForm0 or AllaireTabDockForm1
The DockHost values for the tabs should match that, so when you recreate the
DockHost string make sure it matches.
On a related matter, I noticed that there is a registry value :
HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\ResourceTab]
"DockTabLock"="0"I vaguely recall this being something to lock all the tabs so you can't undock them.
I can't find that in the HomeSite user interface at all. I'll test the registry value,
but does anyone know how you would change it in the HS UI?
thanks, later,
jeff
-- Jeff Wilkinson
volunteer for HomeSite
see Asp4Hs: ASP/PHP/.Net/etc Development Extensions for HomeSite
