1. Re: Anamorphic Pixel Aspect Ratio
Steve Grisetti Apr 27, 2014 7:22 PM (in response to film man 24)There is no anamorphic distortion in 1920x1080 video, since it uses square pixels.
Anamorphic pixels, in fact, are almost unique to tape-based DV and HDV video.
Anamorphic video is purely an electronic thing. It describes the shape of the millions of little pixels that make up every frame of yoru video.
It has nothing to do with the lens you're using on your camera. It also has nothing to do with making your video more cinematic.
Perhaps you're confusing anamorphic or non-square pixels with camera optics, which involves how lenses on a camera or camcorder interpret, reshape or add or reduce depth in an image.
What exactly are you trying to do? Are you trying to make your 16:9 video look more like a 2.35:1 movie frame?
2. Re: Anamorphic Pixel Aspect Ratio
film man 24 Apr 27, 2014 9:21 PM (in response to Steve Grisetti)I could be mistaken..I'm not even sure
Premiere says it will "Conform" the "Pixel Aspect Ratio". When I select "D1/DV NTSC Widescreen 16:9 (1.2121)" the pixel aspect ratio is changed from its original 1.0 square pixel to 1.2121. This is a screen shot of what I have been encountering.
When this happens you do not lose any of the original footage by covering some of it up via a title and you get the "cinematic look" the wide screen look. So Yes, I am trying to get the 2.35:1 movie frame that you mentioned. That’s what I'm ultimately aiming to get. (the clip as you see it has yet to be changed, have not applied it yet so no black bars.This is what it looks like with the "D1/DV NTSC Widescreen 16:9 (1.2121)" conversion applied.
3. Re: Anamorphic Pixel Aspect Ratio
Steve Grisetti Apr 28, 2014 5:51 AM (in response to film man 24)Why is your project set up for DV footage if you're shooting in high def 1920x1080?
In older versions of Premiere Elements, like this one (you appear to be using version 10), you must manually set up your project correctly in order for your video to conform and edit correctly.
Start a new project and, on the New Project option screen, click Settings and select the project preset for DSLR 1080p24.
This should set up your project correctly for your footage (although newer versions of the program work much more efficiently with this video format -- AND will set up your project automatically). You'll know that you've set the project up correctly for your footage because when you add a clip to your timeline, there will NOT be a red line along the top of the timeline, above your video.
Note that, in the illustrations you've provided, there IS red line above the clips.
If your project is set up correctly, you won't need to do things like interpolate your video or work with various pixel aspect ratios. And your finished results will look much better!
4. Re: Anamorphic Pixel Aspect Ratio
film man 24 Apr 28, 2014 10:07 PM (in response to Steve Grisetti)First off, thank you for your input. I'm out of town until Friday but I will try to get back at you soon and I wont be able to run premiere...blastedMy project was not set up to the DV like on the screen shot shows, that is what I was changing the footage to so I would get the black bars on the image without losing any footage from the bars. The project settings are DSLR 1920x1080p, I was just showing you a screen shot of what I was altering the footage to and then the RED bar appeared. The screen shot from the first window has the bar as GREEN but when I streched the footage it went red becasue it has to render the changes I had applied.
I wan't may not be able to be done...
5. Re: Anamorphic Pixel Aspect Ratio
film man 24 May 11, 2014 9:52 PM (in response to film man 24)When widescreen footage is shown ( anamorphic 2:35. 1) is it 16 by 9 footage that just has bars covering it to get the proper proportions or is it 16 by 9 footage compressed to the anamorphic aspect ratio? (given you don't have a anamorphic lens/adapter to shoot true anamorphic)
