Is RoboHelp 9 compatible with Office 2013?
Not officially. If you want to import or link, then it will not work. However, if you only need to create printed documentation, then right click the print layout and select Properties. That way it will work. Obviously if you hit problems, Adobe will not support that but chances are you will be OK.
See item 24 at Using RoboHelp 9
