1. Re: Paragraph Style Bullet List Line Spacing
Obi-wan Kenobi May 13, 2014 9:21 AM (in response to thanser)Hi,
Can you send a screenshot?
2. Re: Paragraph Style Bullet List Line Spacing
thanser May 13, 2014 9:33 AM (in response to Obi-wan Kenobi)Boeing proprietary - sorry.
Every bullet list every made has an extra line between the list items, no matter if you're using inDesign or Microsoft Word. Word actually has a checkbox to remove this extra line space.
Until I can fix this with a Bullet List Paragraph Style, I'm going to do this manually, pasting in the correctly styled bullet character, and tediously aligning the wrapped text line with the Tab bar. (That's too slow.)
Most of my copy in this project are list items, but if I have an extra space between each list item it would be incredibly long.
Thanks.
3. Re: Paragraph Style Bullet List Line Spacing
Obi-wan Kenobi May 13, 2014 9:38 AM (in response to thanser)Without screenshot (even partial), I can't help you because I don't understand your problem.
4. Re: Paragraph Style Bullet List Line Spacing
thanser May 13, 2014 9:51 AM (in response to Obi-wan Kenobi) -
5. Re: Paragraph Style Bullet List Line Spacing
Ellis home May 13, 2014 9:58 AM (in response to thanser)Are you copy/pasting from Word? When you select the text what do you see in Paragraph Style Options/Indents and Spacing/Space After.
6. Re: Paragraph Style Bullet List Line Spacing
P Spier May 13, 2014 9:59 AM (in response to thanser)Extra space is NOT a default for ID and bulleted lists, which means you either have space before or space after (or both) defined in the spacing section of the paragraph style definition.
7. Re: Paragraph Style Bullet List Line Spacing
John Mensinger May 13, 2014 10:03 AM (in response to thanser)Line spacing, (in a list; paragraph spacing), is a product (sum) of character-level "leading" and paragraph-level settings Space Before and Space After.
BUT, that said...
You must be dealing some measure of pre-made or already-existing style(s). InDesign doesn't impose any automatic values upon those settings just because you created a list. I suspect your list has Space Before and/or Space After, but somebody put it there.
8. Re: Paragraph Style Bullet List Line Spacing
thanser May 13, 2014 10:33 AM (in response to John Mensinger)SPACE AFTER.
Fixed it. Rule #1: make sure you've tried EVERY checkbox and parameter before you post a question a forum.
Or maybe I had the PREVIEW box unchecked, and changing the Space After value didn't do anything.
Thanks, everyone.
9. Re: Paragraph Style Bullet List Line Spacing
Obi-wan Kenobi May 13, 2014 10:44 AM (in response to thanser)AND THE WINNER IS... !
