0 Replies Latest reply: May 13, 2014 11:30 AM by nativecoder RSS
    KeywordTokenizerFactory splits the string for the exclamation mark
    nativecoder Community Member
      Hi All
      I have a following field settings in solr schema
      <field name="<b>Exact_Word" omitPositions="true" termVectors="false" omitTermFreqAndPositions="true" compressed="true" type="string_ci" multiValued="false" indexed="true" stored="true" required="false" omitNorms="true"/>
      <field name="Word" compressed="true" type="email_text_ptn" multiValued="false" indexed="true" stored="true" required="false" omitNorms="true"/>
      <fieldtype name="string_ci" class="solr.TextField" sortMissingLast="true" omitNorms="true"><analyzer><tokenizer class="solr.KeywordTokenizerFactory"/><filter class="solr.LowerCaseFilterFactory"/></analyzer></fieldtype>
      <copyField source="Word" dest="Exact_Word"/>
      As you can see Exact_Word has the KeywordTokenizerFactory and that should treat the string as it is.
      Following is my responseHeader. As you can see I am searching my string only in the filed Exact_Word and expecting it to return the Word field and the score
      "responseHeader":{
          "status":0,
          "QTime":14,
          "params":{
            "explainOther":"",
            "fl":"Word,score",
            "debugQuery":"on",
            "indent":"on",
            "start":"0",
            "q":"d!sdasdsdwasd!asd@dsadsadas.edu",
            "qf":"Exact_Word",
            "wt":"json",
            "fq":"",
            "version":"2.2",
            "rows":"10"}},
      But when I enter email with the following string "d!sdasdsdwasdasd@dsadsadas.edu" it splits the string to two. I was under the impression that KeywordTokenizerFactory will treat the string as it is.
      Following is the query debug result. There you can see it has split the word
      "parsedquery":"+((DisjunctionMaxQuery((Exact_Word:d)) -DisjunctionMaxQuery((Exact_Word:sdasdsdwasdasd@dsadsadas.edu)))~1)",
      can someone please tell why it produce the query result as this
      If I put a string without the "!" sign as below, the produced query will be as below
      "parsedquery":"+DisjunctionMaxQuery((Exact_Word:d_sdasdsdwasd_asd@dsadsadas.edu))",. This is what I expected solr to even with the "!" mark. with "_" mark it wont do a string split and treats the string as it is
      I thought if the KeywordTokenizerFactory is applied then it should return the exact string as it is
      Please help me to understand what is going wrong here
