After Effects error: Crash in progress. Last Logged message was: <5304> <GPU Manager> <2> Sniffer Result Code:3
What does this mean and how can I fix it?
We need to know a lot more if we're going to help you. Please provide answers to the questions listed here: "FAQ: What information should I provide when asking a question on this forum?"
after effects error:crash in progress.Last logged message was:<7120><GPUManager><2>Sniffer Result Code:3 what is this?
Hi S5923896,
Make sure Service Pack 1 is installed.
Kevin
Updating my recently installed system to service pack 1 corrected the problem !
Thanks a lot for this answer ,
It did saved my life !
Without proper technical info like system specs nobody can help you specifically. Most of the time this error simply mneans that you need to update your graphics driver.
Mylenium
My system:
Processor 3.5 GHz Intel Core i7
Memory 16 GB 1600 MHz DDR3
Graphics NVIDIA GeForce GTX 780M 4096 MB
Software OS X 10.9.4 (13E28)
After Effects CC (12.2.1)
OS X 10.9.4 (13E28)
No external drivers
Chipset Model: NVIDIA GeForce GTX 780M
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 4096 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x119e
Revision ID: 0x00a2
ROM Revision: 3755
Displays:
iMac:
Display Type: LCD
Resolution: 2560 x 1440
Pixel Depth: 32-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
Built-In: Yes
No
I was having that following problem:
"last logged message was: <988> <prefetch> <5> RequestPrefetchedFrame frame not in async list"
After effects gaved me a chance to save the project and then closed.
I deleted cache, reinstalled the program, and made some other process, but the error apparently was soluted only when I changed the fps of my composition.
That's my case.
Thx.
