We are making a cfhttp call.
We are submitting xml data. We are able to send information from server A to server B, but server B is not giving us any response.
Our code works for coldfusion 8 and 9 but it does not work for coldfusionh 10.
This is the snippet of the code
<cfhttp method="post" url="#httpURL#" timeout="3000" useragent="#CGI.http_user_agent#" >
<cfhttpparam type="XML" value="#xmlRequest#" name="CLRCMRC_XML" >
</cfhttp>
The contents from server B can be access by
<cfdump var="#cfhttp.FileContent#">.
Note This works in coldfusion 8 and 9 but we are not getting any data from server B using coldfusion 10
Issue solved.
It was a matter of changing this line
<REQUEST KEY="#companykey#" PROTOCOL="0" FMT="1" ENCODING="0">
to use PROTOCOL="1"
Could you show us the structure of the URL and how you create the variable xmlRequest?
Assuming server B is also on ColdFusion, is it using getHttpRequestData().content to access the XML contents?
The url is an https call
Below is the xml data being sent to the other server.
<cfxml variable = "xmlRequest">
<cfoutput><REQUEST KEY="#companykey#" PROTOCOL="0" FMT="1" ENCODING="0">
<TRANSACTION>
<FIELDS>
<TERMINAL_ID>#terminalID#</TERMINAL_ID>
<SERVICE_FORMAT>1010</SERVICE_FORMAT> <!--- 1010 = Card not present (E-commerce) --->
<CURRENCY_CODE>124</CURRENCY_CODE> <!--- 124 = Canadian currency code, 840 = us code --->
<CURRENCY_INDICATOR>0</CURRENCY_INDICATOR> <!--- 0 = currency will be processed as a domestic currency transaction --->
<TRANSACTION_INDICATOR>7</TRANSACTION_INDICATOR> <!--- 7 = account information was received through a secure internet site --->
<SERVICE>CC</SERVICE> <!--- CC = Credit Card Transaction--->
<SERVICE_TYPE>DEBIT</SERVICE_TYPE> <!--- DEBIT = CHARGE CC ACCOUNT HOLDER--->
<SERVICE_SUBTYPE>SALE</SERVICE_SUBTYPE> <!--- Authorize and move funds from account holder to merchant--->
<GOODS_INDICATOR>P</GOODS_INDICATOR> <!--- P = physical goods, as opposed to electronic goods --->
<PIN></PIN>
<OPERATOR>Amazingclu</OPERATOR> <!--- operator/location responsible for the transaction generation, in this case, the website--->
<AMOUNT>8</AMOUNT>
<ENTRY_MODE>3</ENTRY_MODE> <!--- 3 = data was manually entered, no card/check present --->
<CVV></CVV>
<EXPIRATION></EXPIRATION>
<ACCOUNT_NUMBER></ACCOUNT_NUMBER>
<FIRST_NAME></FIRST_NAME>
<LAST_NAME></LAST_NAME>
<ADDRESS></ADDRESS>
<CITY></CITY>
<STATE></STATE>
<POSTAL_CODE></POSTAL_CODE>
<PHONE></PHONE>
<COUNTRY></COUNTRY>
<USER_DATA_0></USER_DATA_0> <!--- optional field allowing us to send arbitrary transaction data --->
<!--- <VERBOSE_RESPONSE>1</VERBOSE_RESPONSE> for testing purposes only --->
</FIELDS>
</TRANSACTION>
</REQUEST></cfoutput>
</cfxml>
I used your XML to run the following test. The test page uses cfhttp to post the XML to a CFC. It works as expected, returning the XML.
testPage.cfm
<cfset companykey="myKey123">
<cfset terminalID="ID123">
<TRANSACTION>
<FIELDS>
<PIN></PIN>
<AMOUNT>8</AMOUNT>
<CVV></CVV>
<ADDRESS></ADDRESS>
<CITY></CITY>
<STATE></STATE>
<PHONE></PHONE>
<COUNTRY></COUNTRY>
</FIELDS>
</TRANSACTION>
</cfxml>
<cfhttp url="http://127.0.0.1:8500/workspace/cfhttpTest/MyApp.cfc?method=echoXml" method="post">
<cfhttpparam type="xml" value="#xmlRequest#">
</cfhttp>
MyApp.cfc
component {
remote string function echoXml()
// the request data
var xmlDoc = getHttpRequestData().content;
return toString(xmlDoc);
I solved the issue. The issue had something to do with a setting that returned via tcp/ip and not http.
Issue solved.
to use PROTOCOL="1"
Glad to hear you solved it. Please mark the correct answer, as it will help someone else.
