1. Re: TJ operator does NOT display all glyph
lrosenth May 9, 2014 8:59 AM (in response to OleK)Please post the full PDF so that we can examine all related parts.
2. Re: TJ operator does NOT display all glyph
OleK May 13, 2014 2:03 AM (in response to OleK)You can download the PDF here: https://sourceforge.net/p/pdf-php/discussion/experimental/thread/78be05ac/
Below is the content of this PDF document:
%PDF-1.3
%âãÏÓ 1 0 obj << /Type /Outlines /Count 0 >> endobj 2 0 obj << /Type /Pages /Resources << /ProcSet [/PDF/TEXT/ImageB/ImageC/ImageI] /ColorSpace << /CS0 7 0 R >> /ExtGState << /GS0 17 0 R/GS1 18 0 R >> /Font << /F1 4 0 R /F2 10 0 R >> >> /Count 1 /Kids [3 0 R ] >> endobj 3 0 obj << /Type /Page /Parent 2 0 R /MediaBox [0.000 0.000 595.280 841.890] /CropBox [0.000 0.000 595.280 841.890] /BleedBox [50.000 50.000 545.280 751.890] /Contents [16 0 R 17 0 R ] >> endobj 4 0 obj << /Type /Font /Subtype /Type0 /BaseFont /EECFBD+gothmbok /Name /F1 /Encoding /Identity-H /DescendantFonts [9 0 R] /ToUnicode 6 0 R >> endobj 5 0 obj <</Length1 9464 /Length 9464 >> stream [...] endstream endobj 6 0 obj << /Length 346 >> stream /CIDInit /ProcSet findresource begin 12 dict begin begincmap /CIDSystemInfo <</Registry (Adobe) /Ordering (UCS) /Supplement 0 >> def /CMapName /Adobe-Identity-UCS def /CMapType 2 def 1 begincodespacerange <0000> <FFFF> endcodespacerange 1 beginbfrange <0000> <FFFF> <0000> endbfrange endcmap CMapName currentdict /CMap defineresource pop end end endstream endobj 7 0 obj << /Length 131072 >> stream [...] endstream endobj 8 0 obj << /Type /FontDescriptor /Flags 32 /StemV 70/FontName /EECFBD+gothmbok /Ascent 907 /Descent -170 /FontBBox [-68 -169 1158 907] /ItalicAngle 0.0 /MaxWidth 1158 /MissingWidth 600 /FontFile2 5 0 R >> endobj 9 0 obj << /Type /Font /Subtype /CIDFontType2 /BaseFont /EECFBD+gothmbok /CIDSystemInfo << /Registry (Adobe) /Ordering (Identity) /Supplement 0 >> /FontDescriptor 8 0 R /CIDToGIDMap 7 0 R /W [ 32 [300] 44 [245] 46 [245] 65 [790] 76 [619] 83 [640] 97 [579 664 571 664 592] 103 [664] 105 [263 263 569 263 951 616 646 664 664 405 498 404 616 587] 121 [591] ] >> endobj 10 0 obj << /Type /Font /Subtype /Type0 /BaseFont /BDDBFE+gothmmed /Name /F2 /Encoding /Identity-H /DescendantFonts [15 0 R] /ToUnicode 12 0 R >> endobj 11 0 obj <</Length1 6948 /Length 6948 >> stream [...] endstream endobj 12 0 obj << /Length 346 >> stream /CIDInit /ProcSet findresource begin 12 dict begin begincmap /CIDSystemInfo <</Registry (Adobe) /Ordering (UCS) /Supplement 0 >> def /CMapName /Adobe-Identity-UCS def /CMapType 2 def 1 begincodespacerange <0000> <FFFF> endcodespacerange 1 beginbfrange <0000> <FFFF> <0000> endbfrange endcmap CMapName currentdict /CMap defineresource pop end end endstream endobj 13 0 obj << /Length 131072 >> stream [...] endstream endobj 14 0 obj << /Type /FontDescriptor /Flags 32 /StemV 70/FontName /BDDBFE+gothmmed /Ascent 922 /Descent -172 /FontBBox [-70 -170 1180 922] /ItalicAngle 0.0 /MaxWidth 1180 /MissingWidth 600 /FontFile2 11 0 R >> endobj 15 0 obj << /Type /Font /Subtype /CIDFontType2 /BaseFont /BDDBFE+gothmmed /CIDSystemInfo << /Registry (Adobe) /Ordering (Identity) /Supplement 0 >> /FontDescriptor 14 0 R /CIDToGIDMap 13 0 R /W [ 32 [300] 44 [269] 76 [619] 97 [587 670 571 670 604] 103 [670] 105 [286] 108 [286 950 620 657 670] 114 [413 500 410 620 595] 121 [596] ] >> endobj 16 0 obj << /Length 21 >> stream 0.000 0.000 0.000 rg endstream endobj 17 0 obj << /Length 1826 >> stream 0.000 0.000 0.000 rg BT 297.640 640.940 Td /F1 10.0 Tf () Tj /F2 10.0 Tf [(Lorem) -277 (ipsum) -277 (dolor) -277 (sit) -277 (amet,) -277 (consetetur)] TJ /F1 10.0 Tf ET BT 297.640 630.180 Td /F1 10.0 Tf () Tj /F2 10.0 Tf [(sadipscing) -45 (elitr,) -45 (sed) -45 (diam) -45 (nonumy) -45 (eirmod)] TJ /F1 10.0 Tf ET BT 297.640 619.420 Td /F1 10.0 Tf () Tj /F2 10.0 Tf (tempor invidunt ut labore) Tj /F1 10.0 Tf ET BT 297.640 596.200 Td /F1 10.0 Tf [(Lorem) -331 (ipsum) -331 (dolor) -331 (sit) -331 (amet,) -331 (consetetur)] TJ ET BT 297.640 585.440 Td /F1 10.0 Tf [(sadipscing) 686 (elitr,) 686 (sed) 686 (diam) 686 (nonumy) 686 (eirmod) 686 (tempor)] TJ ET BT 297.640 574.680 Td /F1 10.0 Tf [(invidunt) 681 (ut) 681 (labore) 681 (et) 681 (dolore) 681 (magna) 681 (aliquyam) 681 (erat,)] TJ ET BT 297.640 563.920 Td /F1 10.0 Tf [(sed) 448 (diam) 448 (voluptua.) 448 (At) 448 (vero) 448 (eos) 448 (et) 448 (accusam) 448 (et)] TJ ET BT 297.640 553.160 Td /F1 10.0 Tf [(justo) 422 (duo) 422 (dolores) 422 (et) 422 (ea) 422 (rebum.) 422 (Stet) 422 (clita) 422 (kasd)] TJ ET BT 297.640 542.400 Td /F1 10.0 Tf [(gubergren,) 289 (no) 289 (sea) 289 (takimata) 289 (sanctus) 289 (estLorem)] TJ ET BT 297.640 531.640 Td /F1 10.0 Tf [(ipsum) 694 (dolor) 694 (sit) 694 (amet.) 694 (Lorem) 694 (ipsum) 694 (dolor) 694 (sit) 694 (amet,)] TJ ET BT 297.640 520.880 Td /F1 10.0 Tf (consetetur) Tj ET endstream endobj 18 0 obj << /Title (PDF Document Title) /Author (XXXXXXXX) /Producer (XXXXXXXX) /Description () /Subject () /Creator (XXXXXXXX) /CreationDate (D:20140513105518+00'00') /ModDate (D:20140513105518+00'00') /Trapped /False >> endobj 19 0 obj << /Type /Catalog /Pages 2 0 R >> endobj xref 0 20 0000000000 65535 f 0000000015 00000 n 0000000061 00000 n 0000000280 00000 n 0000000475 00000 n 0000000625 00000 n 0000010154 00000 n 0000010551 00000 n 0000141677 00000 n 0000141889 00000 n 0000142255 00000 n 0000142408 00000 n 0000149422 00000 n 0000149820 00000 n 0000280947 00000 n 0000281161 00000 n 0000281503 00000 n 0000281575 00000 n 0000283454 00000 n 0000283696 00000 n trailer << /Size 20 /Root 19 0 R /Info 18 0 R /ID [<21af1ba34c8347551486c6aca461d433><21af1ba34c8347551486c6aca461d433>] >> startxref 283746 %%EOF -
3. Re: TJ operator does NOT display all glyph
OleK May 13, 2014 7:09 AM (in response to OleK)In addition to this I can provide you a WORKING PDF, which does not have the TJ operator but the Tj (lower-case 'j').
You can download the WORKING PDF here: PHP Pdf creation - R&OS / Discussion / Experimental:TJ (array) operator with embeded TTF subset failure
So the PDF content is 100% identical with the previous post (incl. font program). The only exception is object 17 0.
17 0 obj << /Length 1456 >> stream 0.000 0.000 0.000 rg BT 297.640 640.940 Td /F1 10.0 Tf () Tj /F2 10.0 Tf (Lorem ipsum dolor sit amet, consetetur) Tj /F1 10.0 Tf ET BT 297.640 630.180 Td /F1 10.0 Tf () Tj /F2 10.0 Tf (sadipscing elitr, sed diam nonumy eirmod) Tj /F1 10.0 Tf ET BT 297.640 619.420 Td /F1 10.0 Tf () Tj /F2 10.0 Tf (tempor invidunt ut labore) Tj /F1 10.0 Tf ET BT 297.640 596.200 Td /F1 10.0 Tf (Lorem ipsum dolor sit amet, consetetur) Tj ET BT 297.640 585.440 Td /F1 10.0 Tf (sadipscing elitr, sed diam nonumy eirmod tempor) Tj ET BT 297.640 574.680 Td /F1 10.0 Tf (invidunt ut labore et dolore magna aliquyam erat,) Tj ET BT 297.640 563.920 Td /F1 10.0 Tf (sed diam voluptua. At vero eos et accusam et) Tj ET BT 297.640 553.160 Td /F1 10.0 Tf (justo duo dolores et ea rebum. Stet clita kasd) Tj ET BT 297.640 542.400 Td /F1 10.0 Tf (gubergren, no sea takimata sanctus estLorem) Tj ET BT 297.640 531.640 Td /F1 10.0 Tf (ipsum dolor sit amet. Lorem ipsum dolor sit amet,) Tj ET BT 297.640 520.880 Td /F1 10.0 Tf (consetetur) Tj ET endstream endobj Any ideas?
Here are some screenshots of the "corrupted" PDF:
Chrome looks same as Foxit Reader
4. Re: TJ operator does NOT display all glyph
OleK May 14, 2014 12:51 AM (in response to OleK)Hi Folks,
I finally fixed it!
Because the text is UTF-16BE encoded I mistakenly removed the NULL byte while justifiying.. That causes the problem in Adobe Reader and Acrobat.
Foxit Reader and Chrome Viewer seem to ignore thes null bytes if its string has NULL bytes at the end.
Anyway, it is fixed!
Thank you
Ole K
5. Re: TJ operator does NOT display all glyph
lrosenth May 14, 2014 12:56 AM (in response to OleK)Yup, that would do it!
