We have a number of dynamic XFA (PDF) forms we have sent out to end users. Those end users are in the process of upgrading to Adobe Reader 11.0.07 (Windows, Released 5/13). However upon upgrading, the users when opening the form get a number of modal dialogs with a notice stating "Bad parameter." There can be many dialogs with this same error, one after another. When the errors cease, instead of the actual form being displayed, a boilerplate message notifying the user that they need to upgrade to Adobe Reader 8 appears (see below).
I've tried changing a number of form fields and parameters, but nothing seems to affect the outcome. Does anyone else have this issue?
Solved! Go to Solution.
Total Likes
I believe I have found the culprit of the error, in the XML view:
<?originalXFAVersion http://www.xfa.org/schema/xfa-template/3.3/ DisplayDocTitle:1?>
I removed the DisplayDocTitle:1 part of the tag and the error went away. It would be nice if the Adobe errors actually told you which parameter was bad instead of having to investigate by trial and error.
Total Likes
Try this out
Go to Edit> Preferences> Security and uncheck "Verify signatures when the document is opened"
got it from another discussion:Re: BAD PARAMETER Error when Deleting Pages in Acrobat
Total Likes
I tried what you told me, but unfortunately, it did not change the behavior of the form. I also checked a machine with Adobe Acrobat Pro 11.0.07 and the issue occurs there also.
Total Likes
Total Likes
