CFC DB Inserts and calculations
Jun 19, 2007 Jun 19, 2007
I keep getting a DB CFC error. For some reason CF freaks out when I enter negative numbers into a flash form an pass it to a CFC has anyone else had this problem before? If so can anyone help me figure this out. Again it only freaks out when I enter negative numbers (example: -28).
Sample Code:
Advanced techniques
745
Advocate ,
Can you post the error you are receiving?
oh is a CFC error which is pointing to the Database insert query, and yes I do realize that the code I posted has it comment out but this is not like this on the original file, I think the issue is that coldfusion has issues doing calculations on negative numbers, it should not but this seems to be the case. I even try doing a number format but that won't work because of "-" sign.
Advocate ,
Without seeing the exact error message, its sort of hard to troubleshoot, but the only thing that looks like it would possibly cause an error is the CONVERT() method calls. Since Convert() is a SQL function, the error would be generated by your database and not ColdFusion. Make sure you have the syntax correct. Try removing the single quotes.
all it says is this:
"Error while calling CFC:Error Executing Database query"
I also tried removing the quotes and it did not work. the Convert function is correct because it works just fine when I do not enter negative number in the form and submit.
Advocate ,
Jun 20, 2007 Jun 20, 2007
Have you tried recreating the CF logic on its own CF page (i.e. outside on a CFC) to see if you get a more specific error?
Advocate ,
Also, have you tried calling the CFC from something other than a flash form? I wonder if the flash form is sending another character for the "-" than your DB is expecting. Does it cause the same error when you try to recreate it in a normal HTML form?
Hey I figured out what was wrong with it. It was this "<cfset svc_tech_cont = #NumberFormat(svc_tech_cont, "___.__")#>" The fact that I was doing a numberformat function on it. for some reason SQL Server does not like it. Once I removed it the damn thing works like a charm. Thanks for all your help truly appreciate it.
Documentation
