I was trying to capture a simulation when a pop-up window came with this error:
"A fatal error has occurred and the application is being terminated. Adobe Captivate has tried to save all your work in the respective project folders as ".cpbackup" files.Please restart Adobe Captivate."
I tried every possible solution but i am getting the same error. Even now, i am not able to open a blank project. I cleared Preferences and Cache, Restarted the system, uninstalled and re-installed captivate but the error occurs.
Please help.
Are you running CP as an administrator? Is Captivate installed on your system (not on a networked drive)? Same question for the Captivate Projects and the Cache: on your system, not on a networked drive (you can check paths in Preferences).
I would also once delete the Layouts copy folder in your profile.
Yes all the files on local system and i have admin rights
Having admin rights is not the same as 'Run Captivate as administrator'. For the last, right-click on the start icon for Captivate and check 'Run as administrator'. Or click on Advanced, where you can check the option to always run as administrator.
Another possibility could be a corrupt font somewhere. I forgot to ask which version you are using (exact number).
Which version do you run? I know that some people also had problems with corrupt fonts.
I am having this same issue. My version is 6.0.1.240. Also in the error that I get the word occurred is spelled occured.
