1. Re: Adobe Reader XI Menu Text significantly smaller.
pwillener May 16, 2014 4:27 PM (in response to solcalcutie07)That happened when you updated 11.0.6 to 11.0.7? Strange; I updated a number of computers, none had any such issues.
Could it be a problem of missing or corrupted system fonts?
If I were to experience that problem I would try two things:
- run the System File Checker
sfc /scannow
- revert to 11.0.6 to see if the problem goes away
2. Re: Adobe Reader XI Menu Text significantly smaller.
europeguy4u May 17, 2014 9:23 AM (in response to pwillener)I don't think this is coincidence, cause I run in exactly the same annoying small menu view which cannot be scaled for better reading.
It seems this was meant to be.
Bad choice.
3. Re: Adobe Reader XI Menu Text significantly smaller.
pwillener May 17, 2014 7:32 PM (in response to europeguy4u)I have updated Reader to 11.0.7 on several computers, and none show this problem.
4. Re: Adobe Reader XI Menu Text significantly smaller.
Luc Leroy @ Adobe May 20, 2014 10:51 AM (in response to solcalcutie07)Hi,
We have posted a solution to what seems to be your concern here:
I hope this helps.
Best,
Luc
5. Re: Adobe Reader XI Menu Text significantly smaller.
solcalcutie07 May 20, 2014 10:57 PM (in response to solcalcutie07)Yes, this was in regards to the update to 11.0.7. I downgraded back down to 11.0.6 and was able to restore the font size in the drop down menus back to what it was. Up until now I've never come across any problems with the updates so this is definitely weird to say the least. I went through the other thread and will see if I can pull up the registry on my pc at work tomorrow. At the very least my hope is to see what the current settings are so I have something to compare future settings to. I'll report back later. Thanks a bunch for the input! Glad I'm not the only one experiencing this.
