When I try to select my background or font color I keep getting an exclamation mark. Help
The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
Adobe product and version number
Operating system and version number
The full text of any error message(s)
What you were doing when the problem occurred
Screenshots of the problem
Computer hardware, such as CPU; GPU; amount of RAM; etc.
Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x32
Operating System: Windows 7 32-bit
Version: 6.1 Service Pack 1
System architecture: Intel CPU Family:6, Model:5, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Sorry can't screenshot - in the color picker a black triangle with an exclamation mark appears when I try to select the color that I am trying to use and it doesn't allow me to actually select the color I need
If you are getting this, you might check the color mode to see if your document is RGB/8 or that the layer or mask you select supports color.
If you are in RGB color, click the box below the exclamation point to correct the color.
Also if you select a font color while using the Type Tool, you must click the color swatch in the Type Tool options bar, not the the ones at the bottom of the Toolbox.
I should also mention the black triangle in the color picker means it is not a printable (CMYK offset press) color. If you are displaying your work on screen you can click OK to accept the color you want.
