2. Re: Script: Trim the canvas to remove unused areas from the sides
R_Kelly Apr 25, 2012 7:29 PM (in response to photodrawken)Thanks for posting the script and i'm sure many people will be grateful, since elements doesn't have trim command like photoshop.
3. Re: Script: Trim the canvas to remove unused areas from the sides
photodrawken Apr 25, 2012 7:34 PM (in response to R_Kelly)You're welcome. It's already solved a user's problem. As I said in the other discussion, the very reasonably priced Elements+ add-in provides the additional options for trimming that the "big" Photoshop has:
Ken
P.S., No, I have absolutely no connection with Elements+ other than being a satisfied user.
4. Re: Script: Trim the canvas to remove unused areas from the sides
jpbpds Jul 29, 2012 3:39 PM (in response to photodrawken)Thank you, thank you, thank you! As a former PhotoShop user who's downsized to PSE, it was driving me crazy!
I'm able to figure out most things, but I could't figure out where they hid the "trim" command.
PS: I'll have to check out Elements+
JoAnn
5. Re: Script: Trim the canvas to remove unused areas from the sides
photodrawken Jul 29, 2012 4:05 PM (in response to jpbpds)You're welcome, JoAnn. When it's needed, there's no substitute for "trimming".
Ken
6. Re: Script: Trim the canvas to remove unused areas from the sides
hatstead Jul 30, 2012 6:55 AM (in response to photodrawken)Does this not duplicate the functionality of the recompose tool?
7. Re: Script: Trim the canvas to remove unused areas from the sides
MichelBParis Jul 30, 2012 8:23 AM (in response to photodrawken)Another workaround, in that situation where the subject is surrounded by a transparent background:
- Select the transparent outer background with the magic wand.
- Inverse selection (shift ctrl I)
- menu image/crop
PS: another vote for Elements+
8. Re: Script: Trim the canvas to remove unused areas from the sides
photodrawken Jul 30, 2012 9:08 AM (in response to MichelBParis)Michel,
Yes, that also seems to work when backgrounds are filled with colour.
Ken
9. Re: Script: Trim the canvas to remove unused areas from the sides
photodrawken Jul 30, 2012 9:19 AM (in response to hatstead)hatstead,
Not really -- the Recompose tool will still "squish" objects and alter the spacing between them when the edges are dragged in, and also doesn't work too well on images with multiple layers since you have to recompose each layer separately.
Ken
10. Re: Script: Trim the canvas to remove unused areas from the sides
MichelBParis Jul 30, 2012 9:17 AM (in response to photodrawken)photodrawken wrote:
Michel,
Ken
To be precise :
There might be a selection problem if part of the useful selection is the same color as the background (white part on white background for instance), but in most cases that will not change the trimming.
11. Re: Script: Trim the canvas to remove unused areas from the sides
photodrawken Jul 30, 2012 9:23 AM (in response to MichelBParis)Michel,
Agreed. "Trimming" avoids any issues with selecting.
Ken
12. Re: Script: Trim the canvas to remove unused areas from the sides
debenllc May 18, 2014 1:28 PM (in response to photodrawken)Ken,
when i try to save the Trim.jsx in PSE12 as you describe, I receive a pop up saying that i do not have permission. Any way around this?
Thank you, Richard
13. Re: Script: Trim the canvas to remove unused areas from the sides
debenllc May 18, 2014 1:37 PM (in response to debenllc)Ken,
Please disregard previous post. I was able to copy/paste theTrim.jsx in PSE12 you describe & it works GREAT!!!
