2. Re: I created and distributed my form. How do I see and print the returned form?
Josh_Corey May 20, 2014 10:12 AM (in response to Dori@STC)Hi;
It depends on your account level. This overview will give you some guidance what is available.
In a Free account you can view the Responses on the "View Responses" tab and can export the responses to an Excel spreadsheet or CSV file.
In a Paid level account you can download the response as a PDF form as well as set up Email Notifications so you receive an email of each response that can include the submitted data (with exception of attachments).
This comparison of the plans goes into more detail of the features in each: Compare Plans - Free, Basic, and Plus options | Adobe FormsCentral
Josh
3. Re: I created and distributed my form. How do I see and print the returned form?
Dori@STC May 20, 2014 10:21 AM (in response to Josh_Corey)Josh
Thanks for your response.
I think I figured that out and will have to add the extra services to what I already paid for with Adobe.
So to be clear, I will be able to print the actual completed form I sent to them to fill out? That is what I am needing and I am more than will to pay for it, I just want to make sure I will be able to do that.
Thanks again if you can answer my question further that would be super and then I will purchase the additional needed programs.
Grace, Prayers & Peace
Dori Gass
St. Cecilia Parish
Faith Formation Office
Administrative Assistant
515-232-3514
4. Re: I created and distributed my form. How do I see and print the returned form?
Dori@STC May 20, 2014 10:22 AM (in response to LoriAUC)Lori
Thanks, but I don’t have a save as PDF option. The only thing that prints out is the columns, I need to be able to print the entire sheet they completed and sent back.
Thoughts?
Dori Gass
St. Cecilia Parish
515-232-3514
5. Re: I created and distributed my form. How do I see and print the returned form?
Josh_Corey May 20, 2014 10:31 AM (in response to Dori@STC)Yes - in both the "Basic" and "Plus" level account you will be able to "Download Response as PDF Form" which downloads a PDF that looks like the original form filled out. There are a few caveats to that, the layout may change in the PDF to accommodate fields where the text input was larger than the field, the field will "grow" to display all of the text so it can be printed correctly. Also, attachments would not be included in the downloaded PDF response.
Have a look at this PDF since it goes over designing for PDF, and the information on "Page Breaks" in "Page View" will apply to any PDF saved from the form (not only for distribution, but also the Response PDF), you will want to use that info to add Page Breaks in Page View for your downloaded PDFs: Tutorial: Creating and distributing fillable PDF forms
There are a lot of good FAQ's here as you get started using your subscription: Frequently Asked Questions
There are even more helpful documents here: FormsCentral
Josh
6. Re: I created and distributed my form. How do I see and print the returned form?
Dori@STC May 20, 2014 10:54 AM (in response to Josh_Corey)Thank you again!
I will purchase one of the levels and that should take care of all my needs.
You have been a great help, I am new to these forms and what to make sure I am using them correctly.
Dori Gass
St. Cecilia Parish
515-232-3514
