1
Coldfusion 11 new install - The ColdFusion ODBC Server service is not running or has not been installed.
May 20, 2014 May 20, 2014
I installed the developer edition on my machine and receive the message, "The ColdFusion ODBC Server service is not running or has not been installed." when trying to add an ODBC datasource in the ColdFusion administrator. I previously used ColdFusion 8 with no problems at all adding ODBC datasources. I uninstalled ColdFusion 8 before installing ColdFusion 11.
6.8K
Adobe Employee , May 20, 2014 May 20, 2014
Yes, the fix is in the testing phase. We will share the fix soon.
Anit Kumar
Adobe Employee ,
Hi dlally10,
We are aware about the issue. Here is the Bug# 3759846.
We are working on it with priority.
Anit Kumar
Engaged ,
Jul 07, 2014 Jul 07, 2014
Hi Anit,
I added the following comment on 3759846.  Just also noting the comment here as it contains some workarounds.
Issue #1) CF11's C:\ColdFusion11\cfusion\lib\neo-drivers.xml has 20002 (CF10's ODBC Server port) for both MSAccess and ODBCSocket.
Workaround #1) Open that file and replace all 20002 with 20004 (CF11's ODBC Server port).
Issue #2) CF11's Settings Migration, Datasources page and CAR Deploy feature all write 20002 to C:\ColdFusion11\cfusion\lib\neo-datasource.xml for ODBC DSNs.
Workaround #2) Open that file and replace all 20002 with 20004.
Restart CF after editing those files.
Issue #3) Creating CF11 ODBC DSN fails if CF10's ODBC Server isn't running. (same issue regardless if CF10 was installed or not prior to installing CF11)
Workaround #3) Noted in description for this ticket (install CF10 w/ ODBC support, then create the CF11 ODBC DSN, then stop CF10's ODBC service).
Ticket 3492574 fixed #2 for CF10-only. So #2 again exists in CF11. During Splendor Beta, I added a comment on 3492574 noting this - but there was no reply.
Issue #4) (unresolved ticket 3492620) 64-bit CF11 still requires same-named 32-bit "System DSN" to be manually registered w/ Windows using C:\Windows\SysWOW64\odbcad32.exe. (the "Unable to update the NT registry. Variable DRIVERPATH is undefined." error indicates CF didn't successfully register the DSN as 32-bit - tho the 64-bit registration succeeds)
Issue #5 and #6) (unresolved tickets 3492580 and 3492608) ODBC DSN creation (#5) and deletion (#6) fail in non-cfusion instances. (3492608 has workaround for #5)
Hopefully this port issue can be fixed in a future-proof way. And hopefully CF12 can properly register ODBC DSNs w/ Windows as the correct bitness.
I'm unable to view 3029781. Can this ticket please be made public?
Thanks!,
-Aaron
Adobe Employee ,
Hi Aaron,
I appreciate your time and efforts describing the various aspects. We will look into them.
Anit Kumar
Engaged ,
Hi Anit,
Very cool, thanks!
-Aaron
Aug 17, 2014 Aug 17, 2014
Hi Anit,
I am having the same problem with CF11.  It says CF ODBC not installed.  Can you please send me the hotfix?
Regards, John.
Aug 18, 2014 Aug 18, 2014
John,
I didn't get a response to this thread nor did I get a response to the PM I sent. Instead I sent an email to cf.install@adobe.com and they responded back to me within 30 minutes with the hotfix. If for some reason you don't hear back from them, reach out to me here and I'll send it to you.
Brandon
Guest
We discovered the same issue today as well trying to setup CF11 on a machine that has CF9 & CF10 installed on it and then tried to add Access DBs.
Guest
I tried the work around in the article of starting the ODBC services of CF10 which was offline and that let me add the resources.  However now they all fail to load however.
Error Executing Database Query.
[Macromedia][SequeLink JDBC Driver][SequeLink Server]The specified data source is not defined.
Adobe Employee ,
Hi Leith,
The workaround will not work for ColdFusion 11. We are working on the fix.
Anit Kumar
Guest
Thank you for the update.  Is there an ETA for the fix?
Adobe Employee ,
Anit Kumar
Adobe Employee ,
May 21, 2014 May 21, 2014
Please send me a pm with your contact details and we will send you the hotfix to try.
Anit Kumar
Guest
The hotfix Anit provided me for testing fixed the issue in our environment.  I was able to both add new Access datasources as well as use them in code.  Of note if you added datasources by enabling CF10's ODBC services you must delete them from inside of CF11 and re-add them as they are incorrectly built.
May 24, 2014 May 24, 2014
Since I run into the same problem I woud appreciate to receive a notification about how to get the hotfix to.
Regards
winfried kamps
Adobe Employee ,
May 25, 2014 May 25, 2014
Hi winfried,
Anit Kumar
Good day, Anit Kumar
thanks for contacting me. I confess, I don't know what a pm is, but mij
windows 8.1
member creative cloud
CF 11 server developer edition as intended for local development in
combination with Dreamweaver.
Anit Kumar Panda schreef op 25/05/2014 13:38:
created by Anit Kumar Panda
<https://forums.adobe.com/people/Anit_Kumar> in /ColdFusion/ - View
the full discussion <https://forums.adobe.com/message/6407612#6407612>
Adobe Employee ,
No problems. pm is personal message. Don;t worry. I have already sent you an email with the hotfix and instructions.
windows 8.1
Note:- I have edited your post and deleted personal information.
Anit Kumar
May 26, 2014 May 26, 2014
Hello Anit Kumar Panda
Thank you for providing me with the hotfix.
I applied the two files as suggested.
Having restarted the coldfusion services I was able to start the
procedure to create a DSN.
I was able to chose ms access as driver and to browse to the database file.
Unfortunately after submitting the selected variables, a red error
message occured :
>>Unable to update the NT registry. Variable DRIVERPATH is undefined.<<
and I had to cancel the DSN.
After that the new DSN was listed but the verification resulted in the
message:
Connection verification failed for data source: neg
java.sql.SQLException: [SequeLink JDBC Driver][ODBC
Socket]internal error: The specified DSN contains an architecture
mismatch between the Driver and Application
The root cause was that: java.sql.SQLException: [SequeLink
JDBC Driver][ODBC Socket]internal error: The specified DSN contains an
architecture mismatch between the Driver and Application
So far my experience with the patched cf11 server.
Maybe I should mention that my database file is in the old microsoft
format .mdb
Kind regards
winfried
Anit Kumar Panda schreef op 25/05/2014 23:26:
the full discussion <https://forums.adobe.com/message/6408465#6408465>
Adobe Employee ,
This is a different issue. The issue resolution is available at ColdFusion-10 64bit and MSAccess — Adobe ColdFusion Blog
You may like to check the supported version of MS Access at http://wwwimages.adobe.com/content/dam/Adobe/en/products/coldfusion/pdfs/cf11/coldfusion11-support-m...
Anit Kumar
Guest
May 27, 2014 May 27, 2014
Of note even after you do the steps listed in the article linked you will get a red error at the top saying it can't write to the registry.  This is because you have to use the 32bit ODBC to make this work but it's still trying to access the 64bit registry section instead of the Wow6432Node section.  Just ignore it.
Also you will need to delete any sources you made and start over in the CFIDE.
May 28, 2014 May 28, 2014
thanks Mr Tussing and Mr Panda for your help.
Finally mij developing site came back to life - thank you!
winfried kamps
Leith Tussing schreef op 27/05/2014 14:59:
created by Leith Tussing <https://forums.adobe.com/people/brentil> in
/ColdFusion/ - View the full discussion
<https://forums.adobe.com/message/6411875#6411875>
Aug 14, 2014 Aug 14, 2014
Anit,
I'm having the same issue adding Access Data Sources in CF11. I sent you a PM and also sent an email to the address you provided. Anxiously waiting a reply. Thanks for your help!
Brandon
Aug 28, 2014 Aug 28, 2014
On the bug page: Bug#3759846
It was commented that There is now a fix, and that it will be included in the Upcoming Update of Colfusion 11.
Do we have a date of release for that Update?
Personally I think that this bug deserves it's own update. Why wait for other little fixes to be implemented when you have a big GLARING HOLE in your software?
Isn't this a core feature?
I find it hard to believe that nobody at Adobe took the time to make sure that Coldfusion 11 was actually able to connect to all the types of data sources that it is supposed to be able to connect to.
It's not like this is an obscure bug that comes up rarely! Seriously all you have to do is attempt to add an ODBC datasource and "wow look at that, a bug!"
Isn't such a core feature something that should be tested before software is released?
Apr 19, 2017 Apr 19, 2017
can someone send me this hotfix - i am now having the same problem - ColdFusion ODBC Server service is not running or has not been installed
please help if you can
[Email removed; This is a public forum - private info is not allowed]
CF 11 on a win 10 pro machine trying to set up datasources for MS Access files for the development environment.
Documentation
