I have set up a Solr collection in CF 10 Administrator with following settings:
File Extensions: .*
Directory Path: C:/inetpub/wwwroot/test/
Recursively Index Sub Directories: unchecked
Return URL: http://localhost/test/
Language: Default ( I also tried "English" )
Inside the "C:/inetpub/wwwroot/test/" directory, I have 4 different types of files:.xls, .gif, .cfm, and .pdf. But every time when I try to update the index, none of the PDF fiels are indexed. All the other types of documents are indexed. I have looked at the PDF files' properties, none of them are "locked" or "protected".
I am using the Enterprise trial version with all the updates applied.
Anyone has experienced the same issue before?
Did you figure out why the pdfs would not index? I'm having the same problem, but only on my local machine.
