I'm looking for a fix for what appears to be a bug with
importing interactive Captivate 2.0.0 (build 1177, originally a
trial verson) files into Presenter 6.0.432 (in PowerPoint 2000 SP-3
9.0.8952 on a Windows XP computer).
The course works fine when I publish the Presenter file to My
Computer, but doesn't work correctly when I publish to Adobe
Connect (hosted version). What happens is that the interactive
Captivate simulations are already done. (It seems like Presenter is
somehow completing the simulations before the end user gets to
those slides.)
Each course I've created is approximately 40 slides in length
with approximately eight Captivate demonstrations and eight
Captivate simulations spread out through the course. (A few slides
of content with voiceover, then a slide with a Captivate
demonstration, then a slide with a Captivate simulation slide, etc.
etc.)
Captivate Project Preferences are set to:
Advanced project compression
508 compliance
Compress compiled SWF file
Publish Adobe Connect Enterprise metadata
Captivate Publish settings are:
(unchecked) Export HTML
Flash Player 7
I tried switching the Flash Version to Flash Player 8, but it
didn't help at all, and instead caused an additional problem which
was that the text entry part of the interactive simulations stopped
working altogether.
I'm inclined to think this is a problem with the Connect
server (since the course runs fine when published to My Computer,
just not when published to Adobe Connect), but suppose it could be
a Captivate or Presenter issue. In any case, I'm open to whatever
gets it fixed.
Ruth
