stopping auto run
Guest
Jun 22, 2007 Jun 22, 2007
Greetings, I would like to publish my Captivate move and allow the user to advance one slide at a time. At this point I cannot get the auto run to stop. Is this function possible?
Rich
Getting started
747
Hi Rich
You could accomplish this by inserting a Button object on each slide. Just insert one on the first slide, position and configure it as needed, then copy it to the clipboard via Ctrl+C. Then select the remaining slides in the Film Strip and paste across all the selected slides.
Cheers... Rick
Guest
Rick sould I eliminate the scroll bar then?
Rich
Sorry, but you have confused me. Where are you seeing a scroll bar and how does that factor into what you asked?
Guest
I added a scroll bar to the bottom of my movie just prior to publishing it.
Rich
Hi again
Sorry. Maybe I'm having an off day. I still don't know what you mean by adding a Scroll bar. Are you possibly meaning to say that you added a Playback Control? If that's what you meant, I'm still a bit confused by what this would have to do with adding buttons to pause at each slide.
Cheers... Rick
Guest
Your correct. I used the wrong term. I was using the playback control to allow users to advance to the next frame (slide).
Sounds like this is not necessary if I use a button to move forward and backwards for my training movie.
Sorry for the confusion.
Rich
Hi Rich
No problem. Heck, we are all new at some point, no?
Whether to use a playback control or not is totally up to you. However, I would tend to think that it's probably a bit of overkill if you want the Previous and Next buttons on each slide.
Cheers... Rick
Jun 26, 2007 Jun 26, 2007
Not to rehash the question, however is there a way to stop the movie from auto starting? Allowing the viewer to hit the play button when they are ready to begin viewing.
Thanks for any help anyone can me
Mike
Hi Mike and welcome to our community
If you read through this thread, you will see your answer. Basically, you need to add either a Click Box or a button object to the first slide. This will pause it until your user clicks to allow it to proceed.
I believe in Flash, when you create the .SWF, you have an option to start the .SWF in a paused state. Although I've suggested this feature for Captivate, it does not have the same ability.
Cheers... Rick
Help resources
