To open “Adobe Illustrator CS6,” you need a Java SE 6 runtime
Aug 31, 2012 Aug 31, 2012
I get message when I try to launch a newlt installed version of Illustrator CS6 under mountain lion. Java is not on that machine but do I def have to install it or is there a way around this? Thanks
52.5K
Adobe
Sep 13, 2012 Sep 13, 2012
I got this message, too.  I have the new Java 7 runtime installed direct from Oracle, but it seems either Illustrator or Mountain Lion are insisting on having the Java 6 runtime installed, as well.
I really don't want to have to install both runtimes.  Is there any harm in having both installed?  Is it even possible?
Installed runtime 6 as well.  Illustrator opens fine.
Yes, did the same here and now running fine. Lets just hope they keep Java a little more secure!
Participant ,
Jan 18, 2013 Jan 18, 2013
I just got this "Java SE 6" message on trying to open Illustrator as well.
The odd thing is I've used Illustrator for many months without seeing this alert.
Why would it pop up now?
(AI CS6, Mac osX 10.8.2)
Guest
This from a LA Times story:
"In a rare warning, the U.S. Department of Homeland Security is urging computer users to disable the Java software, citing what it says is a vulnerability in the Oracle's programming platform.
Apple said it is heeding the advice and has remotely disabled Java for most Mac users."
Tom
Participant ,
I think the reason I was running AI *before* was that I actually had java installed. Now I remember that the IT dept. recommeded removing it. I figured that was mainly for browser reasons. But I guess Illustrator depends on it for secret reasons of its own.
Trying to launch AI gives you a button to install Java, which I clicked (I need to use the app! I had to do it!) So now I have java 1.6.0_37. Maybe I had that before IT said it was bad and just didn't know it.
Does anyone know why Illustrator nneds it, but other adobe apps don't?
Participant ,
Jan 20, 2013 Jan 20, 2013
I saw this on
http://securitywatch.pcmag.com/none/307129-if-you-can-t-disable-java-what-can-you-do
"Several Adobe applications also require Java to run certain components. Nothing to worry about, as these are standalone Java applications, and not the ones that run within the Web browser."
So... ok... I guess...
May 24, 2014 May 24, 2014
In case this may be useful for anyone running OSX Mavericks (10.9.3) and encountering the "...need Java se6 runtime..." to launch Illustrator CS6 message, I found the below link on an Apple support page tonight:
Java for OS X 2013-005
I had already de-installed and re-installed Illustrator CS6, thinking this might solve the problem, but I was still getting the "...need java se6 runtime" message.
I assumed because the above link appeared to be for OSX Lion or Mountain Lion, that it wouldn't do me any good since I am running a newer OS (Mavericks). However, after downloading the "Java for OS X 2013-005" that's found via the above link I was able to launch Illustrator CS6.
I've been running OSX Mavericks for a few months and using Illustrator CS6 every day, and had never encountered the "...need Java se6 runtime..." message. What was different for me was, in the last 24 hours, I had the Apple Store re-install OSX Mavericks on my iMac to try to diagnose another issue. The "...need java se6 runtime..." message only started popping up since yesterday's re-install of OSX Mavericks.
I think I recall reading tonight that re-installing OSX Mavericks may wipe out previously-installed versions of Java, or at least this "Java se6 runtime" - whatever that actually is.
Jun 02, 2014 Jun 02, 2014
Just had this error, too in the middle of an urgent project. Seems to be related /w my OS upgrade from 10.6.8 to 10.8.5, cause it did not appear earlier.
Hey, Adobe (I know that there’s stuff members here reading this), would you be so kind what’s going on here
Feb 24, 2015 Feb 24, 2015
Adobe is reading, but NOT DOING... Not even helping here with this problem.  : (
May 20, 2015 May 20, 2015
Download the NEW version of Java from Java.com
Then run the following terminal commands separately.  No fuss no muss.
sudo mkdir -p /System/Library/Java/JavaVirtualMachines/1.6.0.jdk
sudo mkdir -p /System/Library/Java/Support/Deploy.bundle
Nov 09, 2015 Nov 09, 2015
This works. Thanks!
May 27, 2015 May 27, 2015
Works flawlessly /w java version "1.6.0_65".
