Hi ,
I am required to install CFB 3 to support multiple users access on a development environment.
Developers are working on a same server. Once the CFB 3 get installed, only the admin user can run the program but no other.
Whenever the CFB 3 starts, it showed an error message below.
Locking is not possible in the directory
"C:\ColdFusionBuilder3\configuration\org.eclipse.osgi", A common reason is
that the file system or Runtime Environment does not support file locking for
that location. Please choose a different location, or disable file locking
passing "-Dosgi.locking=none" as a VM argument.
C:\ColdFusionBuilder3\configuration\org.eclipse.osgi\.manager\.fileTableLock (Access is denied)
Any clue on how to get this fixed.
Thanks.
Oli
When Eclipse was installed, it was done so as an admin account. This meant that the configuration
folder was accessible and Eclipse thought this was a shared configuration or private install. Because of this Eclipse will first try to write data to the configuration catalog, but will fail for normal users as they do not have permission to modify this file.
For resolution refer ti this post: IBM Error: Locking is not possible in the directory when running in group mode - United States
Milan.
CF Engineering Team.
