1. Re: Is there a substitute tool path for "Image>Adjustments>Variations…" in Photoshop CS6 Standard Addition?
R_Kelly May 28, 2014 7:30 PM (in response to cgrscott)As far as i know, Variations was removed from photoshop cs6 standard/extended and photoshop cc on the mac side
(the windows versions still have the variations command)
You can use Levels in place of variations.
2. Re: Is there a substitute tool path for "Image>Adjustments>Variations…" in Photoshop CS6 Standard Addition?
cgrscott May 28, 2014 9:11 PM (in response to R_Kelly)Thanks, R_Kelly.
You helped me to start exploring other tools in the Image>Adjustments Menu. "Image>Adjustments>Color Balance…" seemed to help me get the results that "Image>Adjustments>Variations…" used to deliver. "Image>Adjustments>Photo Filter>Warming Filter (85)" also got me to where I wanted to be in desired adjustments. I used to get the results I wanted in brightness, contrast, mid-tone adjustment, and color balance buy using just Curves, Variations, and Hue/Saturation. Now I'll use "Color Balance…" and "Photo Filter>Warming Filter (85)" along with Curves, and Hue/Saturation. I also have learned to use "Levels" some more to get the same effect as Adjustments>Variations…" I always thought there were more technically precise adjustment tools to get the same effect as "Image>Adjustments>Variations…" Adobe dropping Variations in Photoshop CS6 Mac version forced me to learn better image adjustment approaches for pre press color correction and image warming. I feel confident now to make Photoshop CS6 my prime-time work tool and move the Photoshop CS4 launch icon off of my Mac OS app Dock. Thanks again, R_Kelly.
3. Re: Is there a substitute tool path for "Image>Adjustments>Variations…" in Photoshop CS6 Standard Addition?
cgrscott May 28, 2014 9:33 PM (in response to cgrscott)(deleted)
4. Re: Is there a substitute tool path for "Image>Adjustments>Variations…" in Photoshop CS6 Standard Addition?
station_two May 28, 2014 9:33 PM (in response to cgrscott)cgrscott wrote:
Before-&-after with Photohop-CS6 using Curves, Hue/Saturation, and Color Balance . . .
Let's see, you dulled the greens of the plants, the yellow of the shirt and the purple of the chair. The wall and the white shirt acquired a distinct and disturbing pinkish cast.
What is the reason you're showing this now?
5. Re: Is there a substitute tool path for "Image>Adjustments>Variations…" in Photoshop CS6 Standard Addition?
station_two May 28, 2014 9:35 PM (in response to cgrscott)Oh, now I see you deleted your images while I was still typing.
