Trying to connect to a webservice behind SSL Proxy with
following url:
https://ssl.xyz.com/is-db/cfc/listingservice.cfc?WSDL,DanaInfo=servername.int.com
if i open this url direct i got a clean XML Page, but if i
use it in a cfinfoke statement i get following error
Could not generate stub objects for web service invocation.
Name:
https://ssl.xyz.com/is-db/cfc/listingservice.cfc?WSDL,DanaInfo=servername.int.com.
WSDL:
org.xml.sax.SAXException: Fatal Error: URI=null Line=15: The
element type "link" must be terminated by the matching end-tag "".
It is recommended that you use a web browser to retrieve and
examine the requested WSDL document for correctness. If the
requested WSDL document can't be retrieved or it is dynamically
generated, it is likely that the target web service has programming
errors.
anyone got an idee about that
Daniel
