How do I deal with an XML file that uses html characters?
Contributor ,
May 28, 2014 May 28, 2014
I need to pull a userlist for my web app, and that involves invoking a web service on the authentication server.  I've managed to do just that, but the XML file I'm given to deal with looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body><ns1:getAllUserInfoResponse soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns1="http://web.ws">
<getAllUserInfoReturn xsi:type="soapenc:string" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/">
&lt;?xml version = '1.0'?&gt;
&lt;USER&gt;
&lt;ROW num=&quot;1&quot;&gt;
&lt;USER_ID&gt;25214&lt;/USER_ID&gt;
&lt;LOGIN_ID&gt;JDOE&lt;/LOGIN_ID&gt;
&lt;NAME_LAST&gt;JOHN&lt;/NAME_LAST&gt;
&lt;NAME_FIRST&gt;DOE&lt;/NAME_FIRST&gt;
&lt;NAME_MI&gt;Q&lt;/NAME_MI&gt;
&lt;NAME_FI&gt;A&lt;/NAME_FI&gt;
&lt;EMAIL&gt;john.doe@email.com&lt;/EMAIL&gt;
&lt;OFFICE_PHONE&gt;5551212&lt;/OFFICE_PHONE&gt;
&lt;OFFICE_STREET1&gt;123 Main Street&lt;/OFFICE_STREET1&gt;
&lt;/ROW&gt; &lt;/USER&gt;
( etc )
</getAllUserInfoReturn>
</ns1:getAllUserInfoResponse>
</soapenv:Body>
</soapenv:Envelope>
I need to loop through this and get usernames, ids, rights, etc, but with it looking like that, I have my work cut out for me (I think).  I'm not sure if there's an easy way to replace entities in an XML file (the docs seem to be down), and if there is, I don't know about it.
Any ideas?
2.4K
Community Expert , May 29, 2014 May 29, 2014
Assuming you have already obtained the XML file using something like <cffile action="read" variable="xmlFile">, then the following single line of code is sufficient:
<cfset xmlDoc=xmlParse(replaceList(xmlFile,'&lt;,&gt;,&quot;','<,>,"'),false)>
Note, however, that
Advocate ,
The document servers are available now.
Have a look at xmlParse: Adobe ColdFusion 9 * XmlParse
Note, however, that your XML would then contain an error. The processing instruction, "<?xml version = '1.0'?>", occurs twice.
Contributor ,
Is this the same for CF8 (which we're currently stuck on)?
I'm getting the XML file from a web service, using cfhttp.  As a result, my data is contained in userlist.filecontent.
I can do this to get rid of the escaped characters (thanks):
<cfset myusers= replaceList(userlist.filecontent,'&lt;,&gt;,&quot;','<,>,"')>
But this errors out:
<cfset listusers= xmlParse(myusers)>
(error parsing xml document)
Contributor ,
Ew, it looks like the problem is with the XML format itself.  I did xmlvalidate() and got this:
struct
errors
array
1 [Error] :1:214: cvc-elt.1: Cannot find the declaration of element 'soapenv:Envelope'.
2 [Error] :1:454: cvc-elt.4.2: Cannot resolve 'soapenc:string' to a type definition for element 'getAllUserInfoReturn'.
fatalerrors
array
1 [Fatal Error] :1:459: The processing instruction target matching "[xX][mM][lL]" is not allowed.
status NO
warnings
array [empty]
I might have to go about this another way.
Contributor ,
Woo! Got it working by using rereplace() to strip out all the bad XML.  Parse now works! Thanks!
You probably saw what I said earlier, namely:
Contributor ,
Yep, but I didn't realize until I tried it that it would prevent the entire thing from working.
This is my first time really working in-depth with XML formatted data.
Documentation
