How to fill shapes with dot pattern
May 28, 2014 May 28, 2014
Does anybody know if it's possible to fill a shape with a dot pattern the way you would with a stroke. I really don't want to create an eps in illustrator and then place into indesign if it will do it for me.
How to
87.3K
Mentor , May 29, 2014 May 29, 2014
As Obi-wan noted, start with a shape
Finish with a grouped set of objects and use Paste Into. (Cut or copy the group, select the frame to fill, Paste Into)
I have used a stoke, set at an angle. I defined the stroke as dotted.
(A custom stoke could control the distance from dot to dot)
I work in values I can divide in my head. 6 pt stoke, step & repeat at 3 or 6 or 9 or 12 pts.
This thread has a script for doing this in Illustrator:
Re: [Ann] Design effect - image made of perfectly arranged circles
No reason to create an EPS file -- just place the AI directly into InDesign.
But when you have a bunch of small dots with a bunch of points it slows down Indesign if you import the ai directly. EPS prevents that. I'm wondering if indesign will just do it so I don't have to go back and forth.
When you Place an .ai file into InDesign, and leave it linked, it functions the same as any other linked file, and will not slow anything down. If anything, creating a complex vector shape directly in InDesign has more potential to slow things down that linking will. In any case, eps is an obsolescent format, and should be avoided.
HI,
ID can do a lot of things (but not coffee!).
If you begin with this:
… want to do that:
… have several actions on the pattern and the shape, directly with ID elements, e.g., as:
… you can do it easily.
Can you make the dots - diagonal lines?
In fact, you can do anything … with the worst taste, if you feel like it!!
Can you tell me how?
… Really (and simply) anything with all the ID powerful features.
3 steps:
1/ prepare the shape.
2/ create the pattern: make the first element (for this, use an object style so that you can easily modify it) and duplicate x times (H and V), to have a "complex pattern".
3. Copy the pattern, select the shape and "paste within" (in French: "coller dedans").
Done!
Mentor ,
Salut Daniel,
In french, it's easier for me. I prefer create a basic pattern element (here, with a circle), apply an object style and duplicate it. That give me much more controls on the pattern: can be anything!
Samples:
