8 Replies Latest reply: May 29, 2014 11:38 PM by Peter Grainge RSS
    Building Native Mobile App for Android: error message, build fail
    saratogacoach Community Member
      I'm  trying RH10 on a Win 8 x64 system, trying to get the generate for  mobile devices, Android to work. I've installed the Android SDK (part of  the complete ADT) in a "Development" folder in the C drive, installed  JDK for Win 64, added the PhoneGap and ANT unzipped folders to the  "Development" folder and then in the RH10 dialog to generate the Android  APK, I've pointed set the correct paths to these tools. (All installed  tools are correct for my OS, Win 8 x64.)
      No  matter what I try, using a sample file (EmployeeCare, Salesbuilder), I  get an error message at the very end of the build process. Please see the screenshot showing the error message and the relevant part of the  log which looks like the ANT path is not working correctly. The build  fails every time. I've tried to do some troubleshooting online and for  example, came across setting the environment variables for the ANT  folder, which I did, but with no success in fixing the problem. The  Eclipse installation connects with the JDK and runs OK if I simply boot  it up.
      My path settings are in a second screenshot below.
      (I've tried the ANT path with different values, for example "C:\Development\apache-ant-1.9.0-bin" etc. Doesn't prevent error message and build failure.)
      I  am not sure what else to do. Any help would be appreciated. At this  point, I would be happy to simply be able to build one APK then test it  on an Android device.
      Thank you for your help.
      Kind Regards,
      saratogacoach
