10 Replies Latest reply: Jun 5, 2014 5:08 PM by Peter Flynn (Adobe) RSS
    Last version not working at all.
    Franck Payen CommunityMVP
      Hi.
      I usually use Brackets, but to answer a question Edge web fonts non intégré (Edge Code) on the french forum, i gave a chance to Edge Code.
      Installed on my mac (10.7.5) via CC, and fell on an issue i already had long ago on brackets : except the main text window, all the rest of the Ui was completely unresponsive : I could click on any menu item, nothing would work, click on icons with no success, even the shortcuts didn't react.
      I had already seen this, so i adviced him to install the last release of Brackets
      What surprised me besides that is that by default, the edge webfonts aren't installed, which, to me sounded like a basic for the Edge family.
      Let me know if you can replicate this, or track it back.
        • 1. Re: Last version not working at all.
          Randy Edmunds Employee Hosts
          Start by going through the Troubleshooting Guide. Let us know if that gets it working or not.
          Randy
          • 2. Re: Last version not working at all.
            Peter Flynn (Adobe) Adobe Employee
            The Edge Web Fonts extension is built into Edge Code -- you should see the icon in the toolbar on the upper-right.  The fonts themselves aren't installed locally, but because thy're webfonts you don't need them installed locally to develop using them.
            - Peter
            • 3. Re: Last version not working at all.
              Randy, i found the behaviour i was looking for there (yep, i search github with my name to find the issue…)
              The advice at that time was to post the logs from the console :
              30/05/14 17:48:11,473 com.apple.launchd.peruser.501: ([0x0-0x9a09a].com.adobe.EdgeCode[3205]) Exited: Terminated: 15
              30/05/14 17:48:19,402 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63db40 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,402 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63dc90 of class __NSArrayM autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,402 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63dcf0 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,404 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63e210 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,404 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63e470 of class NSPathStore2 autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,404 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63e230 of class NSPathStore2 autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,404 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63e2d0 of class __NSArrayI autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,404 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63e620 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,404 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63e4c0 of class __NSCFData autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,404 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3260]: Object 0x7b63e790 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,544 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a6380c0 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,544 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a638210 of class __NSArrayM autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,544 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a638270 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,545 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a638790 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,545 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a6389f0 of class NSPathStore2 autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,545 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a6387b0 of class NSPathStore2 autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,545 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a638850 of class __NSArrayI autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,545 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a638ba0 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,545 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a638a40 of class __NSCFData autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,546 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3263]: Object 0x7a638d10 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,766 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2cc70 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,766 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2cdc0 of class __NSArrayM autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,766 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2ce20 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,767 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2d340 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,767 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2d5a0 of class NSPathStore2 autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,767 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2d360 of class NSPathStore2 autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,767 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2d400 of class __NSArrayI autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,767 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2d750 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,767 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2d5f0 of class __NSCFData autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              30/05/14 17:48:19,767 [0x0-0xa20a2].com.adobe.EdgeCode: objc[3264]: Object 0x79e2d8c0 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
              But this time there are so many extensions into Edge Code !
              AuthenticationUI
              CloseOthers
              CSSCodeHints
              edge-code-informer
              edge-code-inspect
              edge-code-kuler
              edge-code-web-fonts
              HTMLCodeHints
              HtmlEntityCodeHints
              IMSLibConnector
              InlineColorEditor
              InlineTimingFunctionEditor
              JavaScriptCodeHints
              JavaScriptQuickEdit
              JSLint
              LESSSupport
              QuickOpenCSS
              QuickOpenHTML
              QuickOpenJavaScript
              QuickView
              RecentProjects
              StaticServer
              UrlCodeHints
              WebPlatformDocs
              I created a disabled folder with no success…
              • 4. Re: Last version not working at all.
                The extensions in the www/extensions/default folder are "built-in" so you don't need to disable those. Go to the user folder for Edge Code (on Mac):
                  ~/Library/Application Support/Adobe/Edge Code CC
                Start by deleting the cef_data and live-dev-profile folders to clear the caches.
                Then move all extensions in the extensions/user folder to the extension/disabled folder and try again.
                Randy
                • 5. Re: Last version not working at all.
                  Hi Peter, thanks for the answer. I've trashed Code, and installed again via CC (which meant restarting the CC desktop app…)
                  Same problem, nothing seems to be working.
                  This is the installer log from the console :
                  30/05/14 18:09:10,057 installer: Configuring volume "Server HD"
                  30/05/14 18:09:10,070 installer: Free space on "Server HD": 106,03 Go (106031620096 bytes).
                  30/05/14 18:09:10,070 installer: Create temporary directory "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T//Install.35104GLt8U"
                  30/05/14 18:09:10,076 installer: IFPKInstallElement (1 packages)
                  30/05/14 18:09:10,158 authorizationhost: SFBuiltinEntitled: installer is not entitled for system.install.app-store-software
                  30/05/14 18:09:10,183 authorizationhost: SFBuiltinEntitled: installer is not entitled for system.install.app-store-software
                  30/05/14 18:09:10,183 com.apple.SecurityServer: Failed to authorize right 'system.install.app-store-software' by client '/System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd' [3514] for authorization created by '/usr/sbin/installer' [3510]
                  30/05/14 18:09:10,221 installd: PackageKit: ----- Begin install -----
                  30/05/14 18:09:16,146 installd: Installed "Adobe Edge Code CC Preview" ()
                  30/05/14 18:09:16,215 installd: PackageKit: ----- End install -----
                  30/05/14 18:09:16,230 installer: Running install actions
                  30/05/14 18:09:16,231 installer: Removing temporary directory "/var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T//Install.35104GLt8U"
                  30/05/14 18:09:16,233 installer: Finalize disk "Server HD"
                  30/05/14 18:09:16,234 installer: Notifying system of updated components
                  30/05/14 18:09:16,234 installer: **** Summary Information ****
                  30/05/14 18:09:16,234 installer:   Operation      Elapsed time
                  30/05/14 18:09:16,234 installer: -----------------------------
                  30/05/14 18:09:16,234 installer:        disk      0.01 seconds
                  30/05/14 18:09:16,234 installer:      script      0.00 seconds
                  30/05/14 18:09:16,234 installer:        zero      0.01 seconds
                  30/05/14 18:09:16,234 installer:     install      6.15 seconds
                  30/05/14 18:09:16,234 installer:     -total-      6.17 seconds
                  30/05/14 18:09:28,595 Creative Cloud: open on /Users/franckpayen/Library/Application Support/Adobe/OOBE//com.adobe.accc.home/assets/CODE_1.0_24.png: File exists
                  30/05/14 18:09:33,321 Core Sync: Cannot make directory /Library/Application Support/Adobe/CEPServiceManager4/extensions/com.fotolia.fotoliabrowser: Permission denied
                  • 6. Re: Last version not working at all.
                    Thanks Randy. Don't tell Peter, but the only extension i disabled was… pflynn.svg.preview (from September 2013, remain of a former installation i guess)
                    And it's working now.
                    I'll track with the user in the forum if he has this kind of issues.
                    Thanks.
                    • 7. Re: Last version not working at all.
                      Thanks for following up. Log an issue on the repo for that extension: https://github.com/peterflynn/svg-preview
                      Randy
                      • 8. Re: Last version not working at all.
                        Interesting... one other SVG Preview user reported that problem back in February -- see https://github.com/peterflynn/svg-preview/issues/4.  Can you try the suggestion in my last comment there and post back on that thread with the results?  I'd definitely love to pin down what's going on.
                        - Peter
                        • 9. Re: Last version not working at all.
                          Did that to svg preview, no success.
                          What's more surprising is that in Edge Code's extension panel (after clicking the brick icon on the right) I only have the "installed extensions", no "available extensions".
                          Is this expected ?
                          • 10. Re: Last version not working at all.
                            Hi Franck,
                            That's correct -- Edge Code doesn't connect to the open-source Brackets extension listing at this time.  If you want to enable it manually, you can do so by following the instructions here: http://blogs.adobe.com/edgecode/enabling-the-brackets-extension-registry-in-edge-code/
                            - Peter
