3 Replies Latest reply: May 31, 2014 9:49 AM by Rod@FOF RSS
    Make simultaneously or sequentially moveable and editable fields or text sprites in movie.
    Rod@FOF Community Member
      I am having a bit of a problem with creating field or text sprites that are both editable and moveable. I want a user to be able to enter text into the sprites and move them around on the stage to serve as labels for schematics they are making. I can easily make them moveable or editable, but when trying to do both one property interferes with the other. I have been using various combinations of the properties on the mouseenter, mouseleave, and mousedown handlers. One version of my non-workable efforts are below. Seems I can move a sprite but once editable gets focus can't move it anymore.  Any ideas?
      rod
      ___________________________________________________________
      property spritenum
      on mouseenter me
        sprite(spritenum).moveablesprite = true
      sprite(spritenum).editable = false
      end
      on mouseleave me
        sprite(spritenum).moveablesprite = false
      end
      on mousedown me
      end
      on mouseup me
        sprite(spritenum).editable = true
      end
        • 1. Re: Make simultaneously or sequentially moveable and editable fields or text sprites in movie.
          Just a quick p.s. I have been able to achieve the desired action by using an if-then loop on the mousedown. But this is extremely confusing for the users who never know from one moment to the next if they are moving or inputting.
          ______________________________________________________________________________
          property spritenum
          on mouseenter me
          end
          on mouseleave me
          end
          on mousedown me
            if sprite(spritenum).moveablesprite = true then
            else
            end if
          end
          • 2. Re: Make simultaneously or sequentially moveable and editable fields or text sprites in movie.
            Ladnarth Community Member
            Just set your text properties in the property inspector and attach a drag sprite behavior.
            --  Drag sprite
            property  sp  -- this sprite
            property  pStartLoc  --  sprite location upon mouseDown
            property  pMouseStart  -- mouse location upon mouseDown
            property  pMoving  -- flag for enterFrame. True/False
            on beginSprite me
              sp = sprite(me.spriteNum)
              pMoving = false
            end beginSprite
            on mouseDown me
              pStartLoc = sp.loc
              pMouseStart = _mouse.mouseLoc
              pMoving = true
            end mouseDown
            on mouseUp me
              pMoving = false
            end
            on mouseUpoutside me
              pMoving = false
            end
            on enterFrame me
              if not pMoving then exit
              deltaMouse = _mouse.mouseLoc - pMouseStart
              sp.loc = pStartLoc + deltaMouse
            end enterFrame
            • 3. Re: Make simultaneously or sequentially moveable and editable fields or text sprites in movie.
              Thank you for the solution. I like how you worked around the dilemma I faced by allowing the editability of the sprite to be controlled by the property manager leaving only the draggable issue for the mousedown handler. It works 99% well. Only problem is that while dragging some of the text becomes highlighted some of the time and it looks a bit cludgy. But certainly much better than where I started! Thanks again.
              Rod
