If you view the CFC with the CFC viewer you can get the
documentation:-
setOracle
public void setOracle ( string vendor="oracle", string
type="ddtek", required string name, required string host, required
string sid, string originaldsn="", string port="1521", string
driver="Oracle", string class="macromedia.jdbc.MacromediaDriver",
string username="", string password="", boolean
encryptpassword="true", string description="", string args, numeric
MaxPooledStatements, numeric timeout, numeric interval, numeric
login_timeout, numeric buffer, numeric blob_buffer, boolean
enablemaxconnections, numeric maxconnections, boolean pooling,
boolean disable, boolean disable_clob, boolean disable_blob,
boolean select, boolean create, boolean grant, boolean insert,
boolean drop, boolean revoke, boolean update, boolean alter,
boolean storedproc, boolean delete )
Creates or modifies an Oracle data source.
Output: suppressed
Parameters:
vendor: string, optional, vendor - Always Oracle.
type: string, optional, type - Always ddtek.
name: string, required, name - ColdFusion datasource name.
host: string, required, host - Database server host name or
IP address.
sid: string, required, sid - The Oracle System Identifier
that refers to the instance of the Oracle database software running
on the server. ORCL is the default.
originaldsn: string, optional, originaldsn - Original
ColdFusion datasource name, if you are renaming this dsn.
port: string, optional, port - Port that is used to access
the database server. (default 1521)
driver: string, optional, driver - JDBC driver.
class: string, optional, class - JDBC class file.
username: string, optional, username - Database username.
password: string, optional, password - Database password.
encryptpassword: boolean, optional, encryptpassword -
Indicates whether to encrypt the password when storing it in the
neo-query.xml file:
* True – Encrypt the password before storing it.
* False - Store the password in clear text.
Note: If you are updating a data source that already has an
encrypted password, you must set this argument to false to avoid
re-encrypting an encrypted password.
description: string, optional, description - A description
of this data source connection.
args: string, optional, args - Connection string arguments,
formatted (arg1=argvalue;arg2=argvalue).
MaxPooledStatements: numeric, optional, MaxPooledStatements
- The maximum number of pooled statements.
timeout: numeric, optional, timeout - The number of minutes
that ColdFusion maintains an unused connection before destroying
it.
interval: numeric, optional, interval - The time (in
minutes) that the server waits between cycles to check for expired
data source connections to close.
login_timeout: numeric, optional, login_timeout - The number
of seconds before ColdFusion times out the data source connection
login attempt.
buffer: numeric, optional, buffer - The default buffer size,
used if disable_clob is not specified or True. Default is 64000
bytes.
blob_buffer: numeric, optional, blob_buffer - The default
buffer size, used if disable_blob is not specified or True. Default
is 64000 bytes.
enablemaxconnections: boolean, optional,
enablemaxconnections - Enables the maxconnections setting.
maxconnections: numeric, optional, maxconnections - Limit
connections to this maximum amount.
pooling: boolean, optional, pooling - Enable server
connection pooling for your data source.
disable: boolean, optional, disable - Suspends all client
connections to the data source.
disable_clob: boolean, optional, disable_clob - Specify
False to return the entire contents of any CLOB/Text columns in the
database. If you specify False, ColdFusion MX retrieves up to the
amount specified in the buffer argument.
disable_blob: boolean, optional, disable_blob - Specify
False to return the entire contents of any BLOB/Image columns in
the database. If you specify False, ColdFusion MX retrieves up to
the amount specified in the blob_buffer setting.
select: boolean, optional, select - Allow SQL SELECT
statements.
create: boolean, optional, create - Allow SQL CREATE
statements.
grant: boolean, optional, grant - Allow SQL GRANT
statements.
insert: boolean, optional, insert - Allow SQL INSERT
statements.
drop: boolean, optional, drop - Allow SQL DROP statements.
revoke: boolean, optional, revoke - Allow SQL REVOKE
statements.
update: boolean, optional, update - Allow SQL UPDATE
statements.
alter: boolean, optional, alter - Allow SQL ALTER
statements.
storedproc: boolean, optional, storedproc - Allow SQL stored
procedure calls.
delete: boolean, optional, delete - Allow SQL DELETE
statements.
