Show 3 replies
1. Re: Using aspx with Dreamweaver CC
MurraySummers Jun 3, 2014 8:02 AM (in response to sfz5)<nudge>DW does not support ASP or ASPX coding. That was removed in CS5, I believe, so a while ago.</nudge>
There may be a way to make DW show such files, but there is no way to add code hints or server behaviors for either scripting method.
2. Re: Using aspx with Dreamweaver CC
Preran Jun 3, 2014 8:38 AM (in response to sfz5)Hi sfz25,
In addition to what Murray said, you can use the ASP extension to work with ASP files. See Dreamweaver CC: New Document .asp ? for more information.
Preran
3. Re: Using aspx with Dreamweaver CC
polar_bare Jun 3, 2014 3:56 PM (in response to sfz5)http://www.microsoft.com/expression/eng/
If you are working with .aspx, you can download the free version of Microsoft Expression Web. It is no longer supported by MS, but it's a free download. You should be able to get it at the link above.
Jim
