1. Re: Embedded timecode not recognized, all clips start at 00:00:00:00
Cutter61 Aug 1, 2014 11:08 AM (in response to jumpfree29)Hey Jumpfree29
Here's another thread dealing with this issue. Fix appears to be in the works, still.
Pix240 ProRes timecode isn't recognized by Premiere
Cheers
D
2. Re: Embedded timecode not recognized, all clips start at 00:00:00:00
Ann Bens Aug 1, 2014 11:20 AM (in response to jumpfree29)Did you set Preferences/Media/Timecode to Use Media Source?
3. Re: Embedded timecode not recognized, all clips start at 00:00:00:00
Cutter61 Aug 1, 2014 11:24 AM (in response to Ann Bens)Yes. Here's what I posted over there:
[Copied from duplicate thread.]
I'm trying to track down what may be a bug in Premiere Pro 7.2.2.
Exact system details will be added tomorrow when I'm in front of my work machine. OS 10.8.5, Premiere 7.2.2, AJA Kona 3G.
I have 23.98 ProRes 422 footage from an outside post house. They're from a PIX recorder. I am trying to track down the exact model.
Ppro CC (7.2.2) reads this specific set of Qts as starting with "0" timecode. They are in fact time of day (various 10-11-12 hour time codes.)
The preference "Timecode: Use Media Source" is set correctly. (I even tried reversing it just in case).
Ppro CS6 reads them correctly. Final Cut 7 even reads them correctly. Exporting an XML from FCP, in which all TC is correct and matches perfectly (genlocked) results in not only 0 hour TC for each clip in Premiere, but up to 20 second offsets.
I opened The FCP XML in CS6 on my laptop, looked correct. Saved the CS6 project, opened that in 7.2.2 and got the same 0 hour TC and severely mis-aligned multi cam source sequences.
I have a workaround, I'll just run with the incorrect timecode for this one-off project. This will be a real problem, however, down the road.
Anyone else experience this? I found the following 2 threads on Adobe and one from Seth Goldin:
https://forums.adobe.com/thread/1490788
https://forums.adobe.com/message/6365626#6365626
http://sethgoldin.tumblr.com/post/85288214255/premiere-pro-7-2-2-does-not-properly-read-ti me-code
Any insight would be very helpful.
Dan
