0 Replies Latest reply: Jun 5, 2014 9:17 AM by KEPelton RSS
    Unable to sync files due to server error possible solution.
    KEPelton Community Member
      Hi.
      I ran into a problem a couple weeks ago where certain files/folders would not sync. Some would, but others wouldn't. I looked online and in these forums and tried everything and nothing worked. However, I did come across something and it worked for my problem, so I thought I'd share.
      For me, it was not a problem with files but with a folder. I created a sub-folder and subsequently renamed it. Obviously it automatically names it "New Folder", which doesn't help me so I renamed it, for clarity I'll call it "Bob". What I think happened is that CC tried to sync as I was renaming the folder. Because what happened is I got messages saying files were not syncing and now I had two folders, one called "New Folder" and one called "Bob" that were identical. I tried deleting "New Folder" but as soon as I did, it re-synced and put it back. I turned off syncing and deleted it, but when I turned sync back on, it reappeared.
      I checked on CC and saw that it only showed that I had "Bob" and not "New Folder". So I had a phantom folder.
      What I did was:
      1. Turn off file sync.
      2. I moved the entire parent folder of where "New Folder" and "Bob" resided to someplace on my hard drive outside of the Creative Cloud Files directory. This was to ensure it would not be synced.
      3. I deleted "New Folder" on my hard drive.
      4. I went to CC and deleted everything including the parent folder. (archive and delete)
      5. I turned on file sync and everything synced fine without any errors.
      6. I moved the parent folder back into the Creative Cloud Files directory.
      7. When it re-synced, everything worked fine without any errors.
      Not sure if this will help everyone with their issues, but I know it was frustrating to me and I hope it helps. This issue happened to me twice in the past few weeks and this method worked both times. Not sure what exactly is causing the issue. Maybe the delay for doing a sync when adding new files or folders could be increased? Not sure.
      Hope this helps.
      -K
