36 Replies Latest reply on Jul 31, 2007 5:27 AM by elena_f
    Can't start RoboHelp X5
    elena_f Level 1
      I have been working with the RH X5 for a long time but a couple of days ago when starting a project, I got a Windows installer window instead. It was trying to install something for about an hour but then said: can't connect to the server. Whar server? whar was it trying to install? I tried to reinstall the product several times but the result is always the same - installer window hanging:(
      Any idea what can help? Would really appreciate your help
      Elena
        • 1. Re: Can't start RoboHelp X5
          RoboColum(n) Level 5
          Just a hunch. Do you have the "Automatically check for updates" option set and you are not using the latest patch build 5.0.2 Build 801? In this case RH is trying to download the latest build but fails as RH still tries to access the Macromedia website. Turn this option off and manually download the said patch from the Adobe website.
          • 2. Re: Can't start RoboHelp X5
            elena_f Level 1
            Unfortunately, I even can't open it to disable this option. When I click the RH icon to launch the tool, I have this installer window .
            • 3. Re: Can't start RoboHelp X5
              And you are not using RH across a server or network? Have you looked at your task manager to see if that gives some clue as to what is going on? You could try uninstalling and reinstalling?
              • 4. Re: Can't start RoboHelp X5
                elena_f Level 1
                no, I'm not using it across a server or network.
                I reinstalled it several times already with no success. I tried to install an earlier X3 version and launched it successfully but then installed X5 and again saw that Windows Installer window:(
                The task manager doesn't say much to me either:(
                • 5. Re: Can't start RoboHelp X5
                  I'm wondering if the uninstall left some registry entries behind? Try following this link for details on ensuring no trace of RH is left after an uninstall.
                  • 6. Re: Can't start RoboHelp X5
                    Linux Rules Level 2
                    Hello Elena -
                    Something is borked so time to try a work around.
                    What may be happening is this...
                    Your installation of RH X5 probably has some default settings regarding "Automatically check for updates" (under Tools > Options, General tab). If you are running RH5 Office, this setting is in TWO places, not one. You need to launch each executable (not at the same time) and deselect the update option in each.
                    To find your program installation path, right click on your launch icon then click on "Properties". The path is in the "Target" box.
                    I believe the default path is under "Program Files" but I'm not certain as I install to the path I want, not what Macromedia thought was best for me. Anyway, use Windows Explorer to find the RoboHelp installation directory. But first make sure you set Windows Explorer to see what we need to see - forget the Microsoft default settings as they don't know what is best for you.
                    > Open Windows Explorer and navigate to the installed RoboHelp directory.
                    > On the Menu Bar, click "Tools > Folder Options".
                    > In the Folder Options window click the "View" tab.
                    > Under "Files and Folders > Hidden files and folders" click the"Show hidden files and folders" radio button.
                    > Deselect (no check mark) the three boxes that follow (Hide extensions..., Hide protected..., and Launch folder...).
                    > Click the "Apply" button.
                    > Click the "Apply to All Folders" button.
                    > Click the "OK" button.
                    In the RoboHelp parent (installation) directory you will see two subdirectories: RoboHELP and RoboHTML.
                    > Click on the RoboHELP subdirectory.
                    > Scroll down and find "RoboHelp.exe".
                    > Double-click on "RoboHelp.exe" to launch RoboHelp for Word.
                    > A dialog window opens to create or open a project; click the "Cancel" button.
                    > On the Menu Bar click "Tools > Options..."
                    > In the Options window, General tab, deselect (uncheck) "Automatically check for updates".
                    > Close RoboHelp Explorer.
                    Now for the second version...
                    > Click on the RoboHTML subdirectory.
                    > Scroll down and find "RoboHTML.exe".
                    > Double-click on "RoboHTML.exe" to launch RoboHelp HTML.
                    > Optional: select (check) "Use Offline Help" to keep the app from trying to access Macromedia Help via the Internet.
                    > Close RoboHelp HTML.
                    Close Windows Explorer (don't forget to re-set the folder views if you think Microsoft knows what is best for you).
                    Now try to launch your project as you normally do.
                    Let us know if that fixed the problem.
                    GEWB
                    • 7. Re: Can't start RoboHelp X5
                      RoboWizard Level 4
                      Hi all
                      In case everything suggested thus far fails, it's quite possible that something has clobbered something else on your system. In this case, you might try this link.
                      Cheers... Rick
                      • 8. Re: Can't start RoboHelp X5
                        elena_f Level 1
                        I cleaned up the registry following all the instructions but unfortunately it didn't help:(
                        • 9. Re: Can't start RoboHelp X5
                          elena_f Level 1
                          I managed to deselect thi soption for RoboHelp.exe but can't do this for RoboHTML.exe. When I launch it, I have this Installer Window:(
                          • 10. Re: Can't start RoboHelp X5
                            elena_f Level 1
                            Thank you All for the help and advice. Really hope that finally I'll make it work.
                            Regarding the Windows Installer updates, unfortunately it didn't help either. I upgraded to version 3.1, cleaned up all temp directories, tried several methods proposed on msn page - but still have this never-ending windows installer.
                            When I installing the RH, none of the Word versions it proposes to choose is applicable to me (XP, 2003, and 97). I have 2003. I use the default XP selection and say Ok to install the product whereas a proper version of Word is not installed. Probably this windows installer is trying to install Word XP on my machine? Though, when installing RH X3 version I have the same situation with Word and RH is installed and launched with no problem. I'm lost:(
                            • 11. Re: Can't start RoboHelp X5
                              Peter Grainge Adobe Community Professional (Moderator)
                              "none of the Word versions it proposes to choose is applicable to me (XP, 2003, and 97). I have 2003." - Do you mean 2007?
                              • 12. Re: Can't start RoboHelp X5
                                elena_f Level 1
                                I mean that I have Microsoft Word 2003.
                                But RH has only the following options:
                                - Microsoft Word XP
                                - Microsoft Word 2000
                                - Microsoft Word 97
                                • 13. Re: Can't start RoboHelp X5
                                  With a post about an installation problem it would have helped to mention that during installation you were selecting an "invalid" option.
                                  See the Installation topic on my site. Perhaps that will help.
                                  • 14. Re: Can't start RoboHelp X5
                                    elena_f Level 1
                                    You are right. But the same situation for x3 version worked Ok...
                                    • 15. Re: Can't start RoboHelp X5
                                      Yes but the problem is that Word 2003 came out after X5 was released. Peter's site says this and how to get around the problem. With RHX3 Word 2003 was not around so you wouldn't have had the problem.
                                      • 16. Re: Can't start RoboHelp X5
                                        Linux Rules Level 2
                                        quote:
                                        Hello Elena -
                                        The installer for X3 wasn't as picky as for X5 (I despise the newer Microsoft installer for many reasons and now you have experienced just one of them).
                                        You could try uninstalling your Word 2003 and install Word 97 or 2000, then uninstall RH and reinstall RH (and updates), then upgrade your Word to Word 2003.
                                        Note that we use X5 and I installed it with Word 2000 then upgraded to Word 2003 with no problems, at least not with RoboHelp HTML (we do not use Word file import functions).
                                        GEWB
                                        • 17. Re: Can't start RoboHelp X5
                                          I would never advise installing Word after RoboHelp if you plan to import from Word or use printed documentation. What Linux Rules has suggested is OK for the purposes of installing RoboHelp but not if you use Word with RoboHelp.
                                          • 18. Re: Can't start RoboHelp X5
                                            Linux Rules Level 2
                                            quote:
                                            Hello Peter -
                                            True, one should not install Word after RH but we found an upgrade to Word (Office), as opposed to a fresh install of Word, does work for RH.
                                            As I said, we do not use Word with RH, only that Word is required to install RH.
                                            GEWB
                                            • 19. Re: Can't start RoboHelp X5
                                              It's all a bit of a grey area. Adobe advise against it and so many time it causes problems. I've seen patches cause a problem that an uninstall and reinstall fixes.
                                              Against that you've ignored one of the "rules" and it works fine. One day I sat down with a PC and broke nearly every one of the "rules". It all worked absolutely fine!
                                              Also it's not true that Word is needed. It will install without a version of Word on the PC but not with an incorrect one.
                                              • 20. Can't start RoboHelp X5
                                                Linux Rules Level 2
                                                Hello Peter -
                                                I had forgotten that Word wasn't required if one doesn't author in Word...it was too long ago that I installed this version of RH. Thanks for the clearification.
                                                GEWB
                                                • 21. Re: Can't start RoboHelp X5
                                                  elena_f Level 1
                                                  Peter,
                                                  the section on Word 2003 in yur article is mainly addressed to the audience who wants to use Word with RH and can't do that for some reasons. My situation is bit different. I just can't launch the product (specifically, RoboHTML). I already tried to install SP2 but it didn't help and that stubborn windows installer pops up anyway:(
                                                  I wasn't sure that Word was the problem since initially when i was installing x5 with Word 2003, it got installed with no problem. But now I'm ready to use any option. So, probably I should try to follow Linux Rules advice and install Word 2000...
                                                  • 22. Re: Can't start RoboHelp X5
                                                    I'm not convinced this is a RH issue rather than some glitch with your PC to do with the installer. I believe that can happen if your profile has become corrupted or changed. Might be worth checking with IT.
                                                    However given it could be anything here's what I would do.
                                                    1] Uninstall RH as per the link Colum gave you. It's also in the topic on my site.
                                                    2] Install Word 2000.
                                                    3] Install RH.
                                                    4] Check RH works.
                                                    Dependent on what you need to do with RH, decide if you want to go for Word 2003. If you do:
                                                    5] Install Word 2003.
                                                    6] Run RH. In theory it should not work but I have seen it work OK.
                                                    7] If it does not work, then uninstall RH and reinstall it including the patches.
                                                    8] Check RH works.
                                                    Please post back how it goes. It's like watching a serial and we now want to know "who dunnit?"
                                                    • 23. Re: Can't start RoboHelp X5
                                                      elena_f Level 1
                                                      ok, I'll try:) Thanks!
                                                      • 24. Re: Can't start RoboHelp X5
                                                        Guessing you are UK based?
                                                        • 25. Re: Can't start RoboHelp X5
                                                          elena_f Level 1
                                                          Russia:)
                                                          • 26. Re: Can't start RoboHelp X5
                                                            Close! Is English your mother tongue? If not, top marks.
                                                            Just wondering, could any of this be to do with language selections on the PC?
                                                            Not my area if it is.
                                                            • 27. Re: Can't start RoboHelp X5
                                                              elena_f Level 1
                                                              No, it's not. Thank you for the compliment:)
                                                              Not sure about language selections... Never experienced problems with it.
                                                              I'm afraid your guess about the corrupted system profile could be true:( Trying to check it now with IT.
                                                              • 28. Can't start RoboHelp X5
        I was teasing about "close". Don't know if you have seen the video The Wrong Way Round where Ewan McGregor and Charlie Boorman travel from England on motorbikes to the US but via Russia. The statistic that stuck in my mind is that it takes two weeks by train from Moscow to Vladivostock.
        May I ask where you are in Russia? It's always nice to know where people are.
        • 29. Re: Can't start RoboHelp X5
        elena_f Level 1
        Your statistic is correct:)
        I'm from Nizhny Novgorod, middle Russia, about 250 miles from Moscow.
        • 30. Re: Can't start RoboHelp X5
        HKabaker Level 2
        Assuming you have Word 2003 previously installed, you uninstalled RH and cleaned up the registry, and you launched the RH installer . . .
        My recollection is that RH looks for Word on your hard drive and offers to use that version. Since it's not finding Word 2003, maybe there's a conflict among language options used for installation of Win XP, Word 2003 and RH (I forget when RH asks for a language preference).
        Do you have a small icon in the taskbar at bottom right that displays the current language?
        A shot in the dark.
        Harvey
        • 31. Re: Can't start RoboHelp X5
        elena_f Level 1
        RH doesn't offer Word 2003. English locale is enabled on my computer.
        I tried to install RH on a different system (with Word 2003 as well), and it got installed and launched with no problem. So, I suspect Peter was right and my profile got corrupted. So, I decided to reinstall the system and install RH again.
        Thank you All for the help! Really appreciate it.
        • 32. Re: Can't start RoboHelp X5
        Thanks for posting back. (I still think you are English! If not, you had one hell of an English teacher, quite apart from your own efforts).
        • 33. Re: Can't start RoboHelp X5
        elena_f Level 1
        • 34. Re: Can't start RoboHelp X5
        elena_f Level 1
        Hi!
        This is me again with the same problem:( I've been working with the RH on a new system for 3 weeks and today I got that Windows Installer window again!
        No idea what could have happened:( When I installed RH on my new system, I unchecked the 'Automatical update' option for all Robo tools. What is it going to install now - no idea... Shall I go through all these steps again - cleaning up the registry, reinstalling the product?.. I did it before with no success. Don't know what to do:(
        • 35. Re: Can't start RoboHelp X5
        Brian.Mccaffery Level 1
        Sorry to be so late joining the party.
        There is a number of discussions\solution on the following thread.
        Don't know if you have tried any\all.
        Hope something helps,
        Brian
        • 36. Re: Can't start RoboHelp X5
        elena_f Level 1
        Thanks a lot! Solution 2 worked! You are my personal hero!
        Thanks again!
