Show 3 replies
1. Re: How do I connect to a remote server at godaddy
SnakEyez02 Jun 9, 2014 6:09 PM (in response to mchampa)This is an old post of mine but could still be true. Godaddy was improperly signing SSL certificates and could still be doing so if you are using a shared certificate. If you are using your own certificate this should not be an issue and if that is the case please post back. Otherwise, I'm not sure what to recommend.
Dreamweaver CS 5.5 not working with Godaddy FTP with TLS/SSL
2. Re: How do I connect to a remote server at godaddy
mchampa Jun 9, 2014 8:49 PM (in response to SnakEyez02)Thanks Snakeyez,
The cert is a self-signed cert for the server, not a shared one.
Issue might be my configuration. I am moving between two managed servers and right now the old server has my main domain assigned to it and my new server doesn't.
After I finish migration and can repoint my main domain, I will test again to see if that is it.
3. Re: How do I connect to a remote server at godaddy
mchampa Jul 1, 2014 6:35 PM (in response to mchampa)
