Every time I open a pdf I have to manually hide the Navigation Pane as it is taking up valuable real estate on my screen. Is there a way to hide it by default in Reader XI? I've seen it mentioned elsewhere but I've failed to find a satisfactory answer.
Thanks in advance!
Hi rammo123,
For Adobe Reader XI, I change the below mentioned registry key
HKEY_CLASSES_ROOT\AcroExch.Document.11\shell\Read\command
To read:
"C:\Program Files (x86)\Adobe\Reader 11.0\Reader\AcroRd32.exe" /A "navpanes=0" "%1"
~Deepak
Thanks Deepak!
Worked like a charm!
Using regedit in windows 8 under HKEY_CLASSES_ROOT\AcroExch.Document.11\ I'm only showing "(Default)", "BrowseInPlace", and "EditFlags". There is no "shell\Read\command". Is there a different registry key I should edit in Windows 8?
Thanks for the help!
shell\Read\command are subkeys of AcroExch.Document.11, not values:
the subkeys under shell don't include read/command. Where would I be able find it?
Thank You!!
"There is no such thing as a foolproof system. Someone will make a better fool, tomorrow." @LoneWolffe
Thanks Deepak for helping me getting rid of the annoying navigation panel which take up so much valuable space on screen.
For me that works well but only when opening a document from outside Reader (say from File Explorer), when I open from inside Reader the navpane is displayed.
I found how to hide the Navigator Panel in Acrobat XI.
Edit HKEY_CLASSES_ROOT\Acrobat.Document.11\shell\Read\command
to read "C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.exe" /A "navpanes=0" "%1"
I wish Adobe would make this an easy option.
