I am using an access database. I have a table name
strat_data_call which has the fields rec_no, agency, due_dt and a
table named ccd_data_call with fields strat_rec_no, user_id. When
an action takes place against a particular record in the
strat_data_call a record of that action is inserted into the
ccd_data_call table with the rec_no field inserted into the
strat_rec_no field and the cookie.user_id is insertered into the
user_id.
I need to list all the records from the strat_data_call table
which do not have corresponding records that were placed in the
ccd_data_call table by the user who is signed on (cookie.user_id).
The rec_no can be in the ccd_data_call table numerious times but
can only be in there once for any particular user.
How would I write the sql to display this. I have tried
several different joins but none work.
