Hello, I'm with CF11 installed on Windows and a website specifically in error, could you help me?
The isapi_redirect log displays the following:
[Tue Jun 10 09:36:26.079 2014] [8572:1324] [error] isapi_write_client::jk_isapi_plugin.c (1406): WriteClient failed with 995 (0x000003e3)
[Tue Jun 10 09:36:26.079 2014] [8572:1324] [info] ajp_process_callback::jk_ajp_common.c (2030): Writing to client aborted or client network problems
[Tue Jun 10 09:36:26.079 2014] [8572:1324] [info] ajp_service::jk_ajp_common.c (2742): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Tue Jun 10 09:36:26.079 2014] [8572:1324] [info] HttpExtensionProc::jk_isapi_plugin.c (2608): service() failed because client aborted connection
[Tue Jun 10 09:39:41.189 2014] [8572:12972] [info] TerminateFilter::jk_isapi_plugin.c (2668): Jakarta/ISAPI/isapi_redirector/1.2.37 stopping
[Tue Jun 10 09:40:45.820 2014] [8468:8424] [info] init_jk::jk_isapi_plugin.c (2974): Starting Jakarta/ISAPI/isapi_redirector/1.2.37
[Tue Jun 10 09:40:55.835 2014] [8468:8424] [info] init_jk::jk_isapi_plugin.c (3185): Jakarta/ISAPI/isapi_redirector/1.2.37 initialized
[Tue Jun 10 09:40:55.835 2014] [8468:8424] [info] ajp_process_callback::jk_ajp_common.c (2101): current reuse count is 1 of max reuse connection 250 and total endpoint count 250
[Tue Jun 10 09:41:35.225 2014] [2416:2720] [info] init_jk::jk_isapi_plugin.c (2974): Starting Jakarta/ISAPI/isapi_redirector/1.2.37
[Tue Jun 10 09:41:45.240 2014] [2416:2720] [info] init_jk::jk_isapi_plugin.c (3185): Jakarta/ISAPI/isapi_redirector/1.2.37 initialized
[Tue Jun 10 09:41:47.034 2014] [2416:2720] [error] isapi_write_client::jk_isapi_plugin.c (1406): WriteClient failed with 995 (0x000003e3)
[Tue Jun 10 09:41:47.034 2014] [2416:2720] [info] ajp_process_callback::jk_ajp_common.c (2030): Writing to client aborted or client network problems
[Tue Jun 10 09:41:47.034 2014] [2416:2720] [info] ajp_service::jk_ajp_common.c (2742): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Tue Jun 10 09:41:47.034 2014] [2416:2720] [info] HttpExtensionProc::jk_isapi_plugin.c (2608): service() failed because client aborted connection
[Tue Jun 10 09:41:48.079 2014] [2416:9056] [info] ajp_process_callback::jk_ajp_common.c (2101): current reuse count is 1 of max reuse connection 250 and total endpoint count 250
[Tue Jun 10 09:47:06.055 2014] [2416:9056] [error] isapi_write_client::jk_isapi_plugin.c (1406): WriteClient failed with 995 (0x000003e3)
[Tue Jun 10 09:47:06.055 2014] [2416:9056] [info] ajp_process_callback::jk_ajp_common.c (2030): Writing to client aborted or client network problems
[Tue Jun 10 09:47:06.055 2014] [2416:9056] [info] ajp_service::jk_ajp_common.c (2742): (cfusion) sending request to tomcat failed (unrecoverable), because of client write error (attempt=1)
[Tue Jun 10 09:47:06.055 2014] [2416:9056] [info] HttpExtensionProc::jk_isapi_plugin.c (2608): service() failed because client aborted connection
Can you please let me know the error which you see in your web browser?
Priyank
Yes.
Service Unavailable
HTTP Error 503. The service is unavailable.
So you get this error since you configure the Site with ColdFusion 11 and Apache or it works for a while and then it starts throwing this error msg.
Priyank
It works on Windows with IIS 7 and have an error in IIS starts and then stops working.
