Show 3 replies
1. Re: Leading & Vertical Spacing Problem
Willi Adelberger Jun 10, 2014 8:48 PM (in response to thanser)- Do you work with baseline grid?
- Do yu work with Paragraph Styles? You should.
- Why do you have a hard return after each line? Avoid it. Normal return at the end of each paragraph is good, but not a hard return after each line, because it will not allow hyphenation and requires intensive work if changes have to be done.
2. Re: Leading & Vertical Spacing Problem
P Spier Jun 11, 2014 5:36 AM (in response to thanser)Screen shots with non-printing characters would be helpful.
My initial reaction is one of your paragraph styles has space before or space after applied.
3. Re: Leading & Vertical Spacing Problem
thanser Jun 11, 2014 8:04 AM (in response to thanser)Thank you, Peter and Willi.
I went through every page carefully and realize that were some incorrect Paragraph Styles applied to text, that do indeed have 9px of Space After applied. It was driving me crazy and I assumed my character or paragraph styles were applied correctly.
Look for the + sign after the Paragraph Style or check every bit of text to make sure the correct style is applied.
Thanks again.
