upgrade to coldfusion 11
Jun 11, 2014 Jun 11, 2014
I'm working for a few years on a school.
When I started working they were using Coldfusion 9 Enterprise.
I would like to upgrade to Coldfusion 11 Standard.
Looking at Buying guide | Adobe ColdFusion I can' t see a reason to buy the Enterprise for our small website.
Or is there a good reason?
Is it possible to upgrade from Coldfusion 9 Enterprise to a Coldfusion 11 Standard and migrate it from one server to another?
548
Guide , Jun 11, 2014 Jun 11, 2014
@ict-centraal,
If you only run one website, and aren't doing any clustering of ColdFusion and using any of the Enterprise-only features (you'll have to look at one of the feature matrices to see what is Enterprise-only), then you should be fine with Standard.  There are a couple of ways to migrate your settings.  If you create a CAR file from CF9 Administrator, you should be able to import it into CF11.  Just make sure you install CF11 first as a trial (no serial number) and in standalone mode.
Guide ,
@ict-centraal,
If you only run one website, and aren't doing any clustering of ColdFusion and using any of the Enterprise-only features (you'll have to look at one of the feature matrices to see what is Enterprise-only), then you should be fine with Standard.  There are a couple of ways to migrate your settings.  If you create a CAR file from CF9 Administrator, you should be able to import it into CF11.  Just make sure you install CF11 first as a trial (no serial number) and in standalone mode.  Then import the CAR, then once all the settings have been migrated correctly, put in the Standard serial number.
-Carl V.
Jun 12, 2014 Jun 12, 2014
First I will test the Coldfusion 11 in my testenvironment, ESXi.
Create a snapshot and the upgrade to version 11 Standard edition.
And the see if everything on the website is still working.
Hoping everything works with the standard edition: the price difference between standard and enterprise is rather big....
Documentation
