Locked
3
iTunes MobileDevice library not found error when 'Install application on the connected iOS....'
Sep 16, 2013 Sep 16, 2013
After recently upgrading iTunes to 11.0.5.5 I get the following error...
'iTunes MobileDevice library not found. Please check your iTunes installation'
..when selecting 'Install application on the connected iOS device' from the 'Post Publishing' section under the 'Deployment' tab in the 'AIR for iOS settings' dialog box
This used to work? Any ideas?
For now, I can manually use iTunes to add the file to the device, but this does slow down work flow considerably.
Alan.
Development
33.2K
Community Expert , Oct 21, 2015 Oct 21, 2015
installing version 12.1.3 of iTunes failed to solve the problem for me.  i needed version 12.1.2 to solve the problem:
1) Un-install Apple Application support 32 bit/64 bit, Apple Mobile Device Support, Apple Software Update, and iTunes
2) Go to C:\Program Files (x86)\Common Files and delete the Apple folder
3) Go to C:\Program Files\Common Files and delete the Apple folder
4) Go to C:\Users\<your user name>\music\iTunes and delete the .itl file
5) Download and install version 12.1.2 of iTunes: Download Apple iTunes 12.1.2 for Windows 64-bit
replies 103 Replies 103
Sep 19, 2013 Sep 19, 2013
I have just tested this on another PC running Flash Pro CC and ITunes 11.0.5.5 (the same version) and it worked fine, so it's probably some configuration problem with my Flash Installation (I've already installed a newer version of ITunes)
Is there a way to completely reset the installation defaults in Flash Pro CC without re-installing from scratch?
Alan.
Oct 01, 2013 Oct 01, 2013
I have also tried removing iTunes completely and re-installing from scratch and holding Ctrl-Alt-Shift when starting Flash and deleteing all preferences?
Oct 17, 2013 Oct 17, 2013
I have also tried contacting Adobe Customer Support who had no idea and then creating a new user account and trying from there with the same problem.
I also upgraded to IOS7 on the target device to be published to and upgrading iTunes to 11.1.1.11 but still get the error?
Nov 07, 2013 Nov 07, 2013
Here is a screenshot of the error if it helps...
I have also tried removing and re-installing the following: ITunes, QuickTime, Apple Software Update, Apple Mobile Device Support, Bonjour and Apple Application Support.
I'm pretty sure it's an error in the Flash Professional setup somewhere as the same version of Itunes and Flash Pro CC work fine on my Mac.
Contributor ,
Nov 09, 2013 Nov 09, 2013
This feature has NEVER worked for me, so I am skeptical there is any solution.
Jun 11, 2014 Jun 11, 2014
It seems as if someone else has the problem:
https://forums.adobe.com/thread/1438485
I don't know why adobe can't work out what is going on here? It takes such a long time to go through the iTunes process of getting apps onto the iPad.
Nov 18, 2014 Nov 18, 2014
It's now over a year since I posted this and I still haven't found a solution. Both Flash and iTunes have had major new versions but I still have the problem. (and it still works on my Mac)
When I am compiling apps to test on the iPad it takes a considerable amount of time to get each version onto the iPad but when the Post Publishing button worked it was really quick?
Jan 30, 2015 Jan 30, 2015
I just ran into the same thing! Never had any trouble with this and it was working fine just this morning, then iTunes helpfully offered to update. I let it, and now I can't debug!
Going through iTunes to install does work, but it's not really that useful since you can't debug that way. I was in the middle of troubleshooting something and without trace() it's going to be an enormous pain, I'll have to put an on-screen console output in place or something...
I tried manually copying both MobileDevice.dll and iTunesMobileDevice.dll to the Windows directory, Windows/System32, the same directory as idb.exe, since running "idb.exe -devices" as suggested in some other thread I found indicates that one of those DLLs is the problem. I thought maybe the update had placed the DLLs in a different place or something. I tried installing a fresh copy of the latest AIR beta, reinstalling and repairing iTunes. Nothing works.
From the error messages it seems like something changed in iTunes and Air just doesn't know how to deal with it. But like you said it works on some systems and not others. And it's not just Flash CC, I'm using FlashBuilder 4.7 -- so I think it's an Air problem, not a Flash IDE/FB issue.
Interesting note -- Overdrive Media Console also cannot transfer media (audiobooks from my library) to my iPhone, when I did it as recently as a couple of days ago. I assume it uses the same MobileDevice service. Apple must have changed something, so Adobe may be right -- it's Apple's fault (unless you want to fault Adobe for not updating to keep up with Apple, which is a perfectly valid complaint!).
I was able to get mine working again. Tried many, many things but in the end what I ended up doing was uninstalling Apple Application Support (both 32 and 64 bit versions), Apple Mobile Device Support, and iTunes itself using the Control Panel, then reinstalling version 12.0.1 which is what I had before I updated and was able to find available for download via Google. It didn't work the first time I tried that, but did after a second try. Make sure you've seen and accepted a "Trust this computer?" alert on the iDevice too, I'm not sure I had seen that after the first try. I also had to unplug my iPhone and plug it in again after installing before iTunes recognized it.
Now I don't know what exactly finally fixed it, it may be that I could have installed 12.1 again and had it work, and something in the uninstall/reinstall process reset a setting that was causing the problem. But I'm not taking any chances and will leave it alone for now -- I don't actually use iTunes for much of anything anyway, and this is probably the last time I will update this app and I'm planning on switching to something other than Air for any future apps I do.
Feb 01, 2015 Feb 01, 2015
The Mobile device wiki specifically says this is the location of the Mobile Device Library:
  • Location: C:\Program Files\Common Files\Apple\Mobile Device Support\iTunesMobileDevice.dll (Program Files (x86) on 64-bit)
If your iTunesMobileDevice.dll is not in the correct spot, then no porgrams will be able to find the .dll.
I have the same problem and I have been trying to get the directories fixed but no luck so far.
My guess is that my computer runs on a 64 bit operating system and the new release still installs the main files in a 32 bit standard. Hense the reason why the program looks in the Program 86x files instead of the regular program files.
This is most likely both apple's and Adobe's fault. Apple's for not installing it correctly or changing the way their file system works and it is adobe's fault for perhaps not checking that it may be in the programming files instead.
Just a theory. I will still try to solve this problem.
Feb 02, 2015 Feb 02, 2015
Thanks for your help brandandarby and tomc2652178
Unfortunately I still can't get mine working, but that's good news that at least some people with the problem have fixed it.
I have tried multiple times by uninstalling all Apple software and then only installing the 'iTunes 12.1 for Windows (64-bit — for older video cards)' setup above, but I still get the same error?
The iPad can be seen in iTunes and also in the Windows Explorer 'Computer' window under 'portable devices' where I can access photos and video from the device.
I have also checked for the file manually in:
C:\Program Files (x86)\Common Files\Apple\Mobile Device Support
And it is there?
Yeah I strongly suspect there's an element of chance at work here too. The person that started this thread over a year ago was having the same issue with a much older version, and people with the same exact setup don't have the problem while others do. In my case it also broke OverDrive Media Console, so it's not just Air/Flash/Flex.
It feels like during updates, something sometimes goes wrong -- like maybe the new version doesn't update a path somewhere in the settings. In my case going back to the same version I last had installed and working seemed to do it, but only after uninstalling/reinstalling twice. No idea how that's even possible... Probably uninstalling and clearing out all settings using RegEdit or something might do the trick because it definitely leaves a lot of settings behind when uninstalling.
If you know exactly which version you had working last and can find an installer for it, I'd try that, and may uninstalling/reinstalling a couple of times.
I do not know how much chance is put into this. I carefully kept track of all the folders and files that were installed each time I installed iTunes. Nothing changed. No matter how many times you may install a program it will still keep the files in the same place unless you have a conflict such as a folder with the same name. But I suspect that he wasn't playing around in his programming files. I probaby re-istalled the most recent iTunes 8x with out any change. Even with uninstalling everything. I finnally had the idea of bit file misplacement when I installed an older version of itunes and shifted through the files.
Enthusiast ,
I have the same problem.
1) Windows 8
2)
C:\Program Files (x86)\Common Files\Apple:
C:\Program Files\Common Files\Apple:
CoreFP
I need the bit of your computer specifically. 32 bit or 64 bit? @ Lars
Enthusiast ,
64bit
Please list the following info so I may help you.
1) Operating System
2) The Folder names in this location of your computer:
    and
   ( this may help me get an idea of what may be out of place )
The problem is the way the application is installed. The file locations matter. Thats why flash is looking for the file and can't find it. There are many reasons why flash may not still be able to find it. 1)  iTunes is installed incorrectly ( not your fault ). 2) You might have a diferent bit program of flash professional. But I am almost positive adobe installs their programs depending on the bit of one's computer.
1 - Windows 7 Home Premium Service Pack 1 - 64bit
2 - In
C:\Program Files (x86)\Common Files\Apple -
CoreFP
C:\Program Files\Common Files\Apple -
CoreFP (only contains file 'CoreFP.dll)
Mobile Device Support (contains 'drivers' folder, 'NetDrivers' folder and 1 file - 'OutlookChangeNotifierAddIn.dll'
Note that in the 'C:\Program Files (x86)\Common Files\Apple\Mobile Device Support' folder are all these:
AirTrafficHost.dll
AppleMobileBackup.exe
AppleMobileBackup_main.dll
AppleMobileDeviceHelper.exe
AppleMobileDeviceHelper.resources
AppleMobileDeviceHelper_main.dll
AppleMobileDeviceService.exe
AppleMobileDeviceService_main.dll
AppleMobileSync.exe
AppleMobileSync_main.dll
AppleSyncMapiInterface.dll
AppleSyncMapiInterfaceHelper_x64.exe
ATH.dll
ATH.exe
ATH_main.dll
com.apple.IE.client.exe
com.apple.IE.client.resources
com.apple.IE.client_main.dll
com.apple.MobileSync.client.resources
com.apple.Outlook.client.exe
com.apple.Outlook.client.resources
com.apple.Outlook.client_main.dll
com.apple.Safari.client.exe
com.apple.Safari.client.resources
com.apple.Safari.client_main.dll
com.apple.WindowsContacts.client.exe
com.apple.WindowsContacts.client.resources
com.apple.WindowsContacts.client_main.dll
com.apple.WindowsMail.client.exe
com.apple.WindowsMail.client.resources
com.apple.WindowsMail.client_main.dll
DeviceLink.dll
iSyncConduit.dll
libcurl.dll
libeay32.dll
MDCrashReportTool.exe
MDCrashReportTool_main.dll
Mingler.exe
Mingler_main.dll
MobileDevice.dll
output.txt
ssleay32.dll
SyncDiagnostics.exe
SyncDiagnostics_main.dll
syncli.exe
syncli_main.dll
SyncPlanObserver.exe
SyncPlanObserver_main.dll
SyncServer.exe
SyncServer_main.dll
SyncServices
SyncServices.dll
SyncServicesUI.dll
SyncServicesUI.Resources
SyncUICore.dll
SyncUICore.Resources
SyncUIHandler.exe
SyncUIHandlerDll.dll
SyncUIHandler_main.dll
upgradedb.exe
upgradedb_main.dll
I think I might have your solution. The problem was the file placement. Even though my graphics card is a high end gpu I still installed this version because it is the most recent and the files install correctly. This fixed my Mobile Device Library not found error.
Hope this helps.
Cheers.
Engaged ,
just ran in to this problem after updating itunes. simple uninstall/reinstall did not fix
its also the same problem for "unable to enumerate devices" in adt
I did fix it though with the help of this thread thanks everyone!
uninstalled apple application support 32 and 64bit,  apple mobile device support and itunes
then I installed "itunes for older video cards" that brandandarby posted.
thanks again....any time I touch I tunes it f*cking bombs my computer
I'm glad to hear that. Please try to hit the like button if that helped so people may find the answer quicker.
But the reason this is happening is most likely on 64 bit computers the main iTunes files are being stored in Program Files rather than Program( 86x ) files. If you have a 64x bit computer and iTunes wants to install it in Program Files, this might not be the program you want then.
I think you're right -- it's definitely a file placement issue but no amount of moving that DLL around helped. Probably there's a path stored somewhere that's wrong. This sounds like a likely fix -- the version of iTunes for older cards probably installs different support files or something. I'm downloading and will hold on to it in case something goes wrong, but I don't dare actually try it now that mine's working again considering that I don't actually use iTunes for anything except this and copying things to/from my iOS devices, both of which work just fine.
Apr 03, 2015 Apr 03, 2015
I just wanted to say thank you to brandanarby! I have been troubleshooting this one for a while. I uninstalled all of the Apple apps and reinstalled using the link he provided and my device is now being detected in Flash. Thank you sir!
