We have two separate box, one is for Web Server ( Apache 2.2.24 ) and another one is Application Server ( CF10 ). Is it possible to connect them.
If possible, please share some document url regarding that.
Thanks.
Steps of distributing environment is same as creating connector manually on the same box, only difference is when you work on distributed environment you need to add the IP address of your ColdFusion server machine to the Apache machine.
You have to create the same directory structure in the Apache machine, where you can put all the connector files. it's like /opt/ColdFusion10/config/wsconfig/Magic_Number
Here is the article for manual connector configuration with Apache.
ColdFusion10 Apache manual connector configuration
On Step number 4
Thanks for your prompt Answer.
Let me try it and get back to you. And one more clarification as per ColdFusion matrix Apache 2.2.21 version is there. And we are using 2.2.24, for that is their any issue ??
Apache 2.2.24 will work, please let me know in case of any issue, I am documenting Distributed Environment with ColdFusion 10+Apache and will share the document here.
Priyank
