1 2 Previous Next 59 Replies Latest reply: May 30, 2008 10:29 PM by Arnout Kazemier RSS
    Spry 1.5 and dw cs3
    Michele Bedin Community Member
      How do I update spry from 1.4 to 1.5 version in dreamweaver cs3 ? I have tried with update function in help menu but not send me messages with new versions available to download... thanks
        • 1. Re: Spry 1.5 and dw cs3
          Diana Ispas Community Member
          Hi Michele,
          For the moment we don't have an automatic way to update the files from spry 1.4 to 1.5.
          What you can do is to copy the new css and js files from spry 1.5 version over your existent spry 1.4.
          You can unzip the package from spry site inside the SpryAssests folder from DW.
          Diana
          • 2. Re: Spry 1.5 and dw cs3
            thanks Barascu but I have some problem... I have downloaded the new version but I don't found SpryAssests folder in "Application Data/Adobe/Dreamweaver 9/configuration/".. only SpryAssests folder is in the root website...
            • 3. Re: Spry 1.5 and dw cs3
              The path for the spry files is: ProgramFiles\Adobe\Adobe Dreamweaver CS3\configuration\Shared\Spry\ There you have the folders: Data, Effects and Widgets. You have to replace every js and css file for each widget, for effecst and also for Data.
              If you go and replace these spry 1.4 files with the spry 1.5 files, every time when you apply an widget, add an effect or create some data set stuff, the js and css files generated will be always the Spry 1.5 files. In this way, if at a moment you will want to use something from Spry 1.4 we'll not have these files anymore,.
              If you really want to change these files, my recommendation is to make a copy of the Spry folder from the path I mentioned above,having anyway the Spry 1.4 version saved on your disk. Also, if you have the js and css files from Spry 1.4 already generated in SpryAssets folder from your site root, you can make a copy to this folder.
              Maybe the safest way is to change to Spry 1.5 only the css and js files from SpryAssets folder placed on your site root. In this way, if you'll need something from Spry 1.4 just delete the files from Assets folder and DW will generate them as Spry 1.4.
              Hope this helps,
              Diana
              • 4. Spry 1.5 and dw cs3
                Actually I have these folder:
                Data
                DesignTime
                Effects
                Widgets
                In "Data" folder I have these file:
                SpryData.js
                SpryXML.js
                xpath.js
                In "DesignTime":
                EditingUtils.js
                WidgetBase.js
                WidgetManager.js
                In "Effects":
                SpryEffects.js
                In "Widgets":
                Accordation (with designtime folder)
                CollapsiblePanel (with designtime folder)
                MenuBar (with designtime folder)
                TabbedPanels (with designtime folder)
                ValidationCheckbox (with designtime folder)
                ValidationSelect (with designtime folder)
                ValidationTextarea (with designtime folder)
                ValidationTextField (with designtime folder)
                I don't found the exact file corrispondation in the "spry_p1_5_051707" folder...
                is possible from Adobe create a pdf with exact upgrade procedure ? I wouldn't like to create problem with my dreamweaver configuration ... thanks
                • 5. Re: Spry 1.5 and dw cs3
                  ColdSun Community Member
                  Do you have to change the CSS files? I've made quite a few changes to the horizontal menu CSS and the Tabbed Panels CSS. I'll have to do it over again if we have to replace them. Just want to know for sure before I start doing the work. :)
                  • 6. Re: Spry 1.5 and dw cs3
                    kinblas Community Member
                    Before folks go modifying their Dreamweaver CS3 installs manually, let me just explain how Dreamweaver handles the Spry files so you know exactly what goes on. This post is long, but read it in its entirety.
                    MAKE A BACKUP OF ANYTHING YOU PLAN ON CHANGING/UPDATING, JUST IN CASE YOU NEED TO RESTORE IT.
                    Dreamweaver only copies Spry files to your site if you save a page in which you've added a Spry Widget, Effect, and/or DataSets/Regions. It does this copy when you save, but it will only copy the files to your site if the file does not already exist in your site, that way it doesn't blow away any Spry file you may have modified in your site. Dreamweaver only copies the minimal set of files necessary to support whatever it is you added to your page, so if you've added an accordion to your page, it only checks for the existence of SpryAccordion.js and SpryAccordion.css before it actually copies those 2 files into your site.
                    That all said, if you already have say an Accordion in one of your pages in your site, you should already have a SpryAssets folder with the 1.4+ SpryAccordion.js and SpryAccordion.css in it. If you replace your Spry 1.4+ copies of SpryAccordion.js and SpryAccordion.css in your Dreamweaver Configuration directory, and then you create a new file for your site which uses an Accordion, it will *NOT* copy over the 1.5 versions of the file from the Configuration directory into your Site's SpryAssets directory because DW wants to play it safe and not overwrite the existing ones in your site. This means you will also have to manually copy the 1.5 files to your site if you want your site updated too.
                    After you update your Dreamweaver configuration folder to contain the 1.5 files, if you create a new site, or create new page in an existing site and add a widget, or effect that you have never used before, the 1.5 versions will be copied into the site. All of these Spry files are independent of each other, so you should be able to mix 1.4 and 1.5 files with no problems.
                    That all said, we are working on an extension that will help folks install the latest Spry files into their installed Dreamweaver configuration *and* into their sites. At this point in time, we cannot commit to an e.t.a. for this extension yet, but we will keep folks posted.
                    Here are the paths to the Spry 1.4+ files in the Installed Dreamweaver Configuration folder which you will need to update:
                    Configuration/Shared/Spry/Data/SpryData.js
                    Configuration/Shared/Spry/Data/SpryXML.js
                    Configuration/Shared/Spry/Data/xpath.js
                    Configuration/Shared/Spry/Effects/SpryEffects.js
                    Configuration/Shared/Spry/Widgets/Accordion/SpryAccordion.css
                    Configuration/Shared/Spry/Widgets/Accordion/SpryAccordion.js
                    Configuration/Shared/Spry/Widgets/CollapsiblePanel/SpryCollapsiblePanel.css
                    Configuration/Shared/Spry/Widgets/CollapsiblePanel/SpryCollapsiblePanel.js
                    Configuration/Shared/Spry/Widgets/MenuBar/SpryMenuBar.js
                    Configuration/Shared/Spry/Widgets/MenuBar/SpryMenuBarHorizontal.css
                    Configuration/Shared/Spry/Widgets/MenuBar/SpryMenuBarVertical.css
                    Configuration/Shared/Spry/Widgets/TabbedPanels/SpryTabbedPanels.css
                    Configuration/Shared/Spry/Widgets/TabbedPanels/SpryTabbedPanels.js
                    Configuration/Shared/Spry/Widgets/ValidationCheckbox/SpryValidationCheckbox.css
                    Configuration/Shared/Spry/Widgets/ValidationCheckbox/SpryValidationCheckbox.js
                    Configuration/Shared/Spry/Widgets/ValidationSelect/SpryValidationSelect.css
                    Configuration/Shared/Spry/Widgets/ValidationSelect/SpryValidationSelect.js
                    Configuration/Shared/Spry/Widgets/ValidationTextarea/SpryValidationTextarea.css
                    Configuration/Shared/Spry/Widgets/ValidationTextarea/SpryValidationTextarea.js
                    Configuration/Shared/Spry/Widgets/ValidationTextField/SpryValidationTextField.css
                    Configuration/Shared/Spry/Widgets/ValidationTextField/SpryValidationTextField.js
                    Here are the paths to the files in the Spry 1.5 zip file:
                    includes/SpryData.js
                    includes/SpryXML.js
                    includes/xpath.js
                    widgets/accordion/SpryAccordion.css
                    widgets/accordion/SpryAccordion.js
                    widgets/checkboxvalidation/SpryValidationCheckbox.css
                    widgets/checkboxvalidation/SpryValidationCheckbox.js
                    widgets/collapsiblepanel/SpryCollapsiblePanel.css
                    widgets/collapsiblepanel/SpryCollapsiblePanel.js
                    widgets/menubar/SpryMenuBar.js
                    widgets/menubar/SpryMenuBarHorizontal.css
                    widgets/menubar/SpryMenuBarVertical.css
                    widgets/selectvalidation/SpryValidationSelect.css
                    widgets/selectvalidation/SpryValidationSelect.js
                    widgets/tabbedpanels/SpryTabbedPanels.css
                    widgets/tabbedpanels/SpryTabbedPanels.js
                    widgets/textareavalidation/SpryValidationTextarea.css
                    widgets/textareavalidation/SpryValidationTextarea.js
                    widgets/textfieldvalidation/SpryValidationTextField.css
                    widgets/textfieldvalidation/SpryValidationTextField.js
                    To answer ColdSun's question regarding the CSS files. With the exception of SpryValidationTextField.css, there were no significant changes to the CSS files between Dreamweaver's 1.4+ version and Spry 1.5 except for comment corrections. For the SpryValidationTextField.css we added an extra dummy rule to show folks that there is now a behavior class that allows you to style Hint Text differently. As I mentioned, even if you install these new CSS files, Dreamweaver will *NOT* overwrite the CSS file with the same name in your site.
                    Remember:
                    MAKE A BACKUP OF ANYTHING YOU PLAN ON CHANGING/UPDATING, JUST IN CASE YOU NEED TO RESTORE IT!
                    And one last thing:
                    --== Kin ==--
                    • 7. Re: Spry 1.5 and dw cs3
                      fmpdan Community Member
                      The kinblas post was very helpful. I still am a little confused about the files in the include directory go. SpryData and XML and xpath .js are covered and replace existing files. There are a whole set of new files in there that might go in the data file but they are not listed anywhere on the post.
                      like debug and util .js files. And the files in the css directory I would thing the Sprydebug might be needed but not sure where these should go.
                      • 8. Re: Spry 1.5 and dw cs3
                        cdub8600 Community Member
                        Does anyone have a backup up of their 1.4 folder for mac. seams that even with all those notes to make a backup, I still managed to F*** things up. Thanks.
                        • 9. Re: Spry 1.5 and dw cs3
                          cdub8600
                          contact me back channel seems no way to attach a file here
                          • 10. Re: Spry 1.5 and dw cs3
                            woops sorry dan@dss-db.com
                            • 11. Spry 1.5 and dw cs3
                              I have updated the old 1.4 file with new 1.5 in "...configuration\Shared\Spry\" but I haven't found these file (in "DesignTime" folder):
                              EditingUtils.js
                              WidgetBase.js
                              WidgetManager.js
                              is necessary to update above file or not ?
                              ... and ... which are the new functions available in 1.5 version that actually are not present in dreamweaver cs3 and is necessary to insert manually ?
                              thanks
                              • 12. Re: Spry 1.5 and dw cs3
                                Marcell Branco Community Member
                                I have updated my Dreamweaver configuration folder with the new Spry 1.5 files as described by Kin. However, I noticed that in each widget's folder on my configuration folder there is a "DesignTime" folder containding a [widget's name]DesignTime.js file (e.g. ..\Spry\Wdget\Accordion\DesignTime\SpryAccordionDesignTime.js). Should not these files be updated as well?
                                • 13. Re: Spry 1.5 and dw cs3
                                  To answer Michele and Marcell's questions in one swoop:
                                  Dreamweaver only knows about specific Spry Framework files that are necessary to support the features that are available in Dreamweaver CS3 ... the list of files I mentioned above are the only Spry framework files that folks have to update in Dreamweaver CS3 to get it to copy Spry 1.5 files to your sites instead of the default 1.4 that ships with DW CS3. If a file isn't in that list, it is not part of the Spry Framework and is something specific to Dreamweaver, so I advise folks not to touch/edit those other files.
                                  To see a list of changes/fixes for Spry 1.5, take a look at this file:
                                  http://labs.adobe.com/technologies/spry/ChangeLog.html
                                  Which is also in the Spry Pre-Release 1.5 zip.
                                  Folks really don't need to update their DW CS3 install unless they want a specific fix or feature, and they want DW to automatically copy the 1.5 files when they create new sites.
                                  Another alternative to updating the Dreamweaver config files, would be to copy the files from the 1.5 zip directly into your site's SpryAssets folder. By doing so, you will prevent DW from copying any Spry files from its config folder into your site, because it is already in your site.
                                  --== Kin ==--
                                  • 14. Re: Spry 1.5 and dw cs3
                                    Thanks Kin
                                    • 15. Spry 1.5 and dw cs3
                                      thanks ... I hope to see soon the extension for automatic update (and for insert the new functions/effects available in 1.5 version) because now dreamweaver cs3, only after 1 mounth to lunch, is an old product... only reason for me to upgrade dreamweaver 8 to cs3 was spry integration...
                                      • 16. Re: Spry 1.5 and dw cs3
                                        SaschaSchwartz Community Member
                                        I absolutely aggree with Michele Bedin, you should offer an upgrade installer for 1.5 which inserts all possibilities of spry 1.5 to Dreamwaever CS3. I am also pretty disapointed. I mean i just got the whole Studio a few weeks ago and one of the major reasons was spry integration. It took me whole day to understand that only with spry 1.5 i can use html entity decoding by placing the files manually into the folders. That's not what i expect for such a high value product.
                                        • 17. Re: Spry 1.5 and dw cs3
                                          skeeze Community Member
                                          Once the functions are updated in DW, can you still use the interface in DW to update data elements of Spry objects like menus? (i.e. adding menu items). In theory it should still work because this is only updating the CSS code and according to the above posts there is little or no change to the CSS structure.
                                          Also, with version 1.4, if you click on a Spry object from within DW you can modify the properties to be open by default, closed by default, animate, etc. Since with the way the new effect functions are called are different, will it update the code in the page correctly, or does everything have to be done by hand?
                                          • 18. Re: Spry 1.5 and dw cs3
                                            Hi skeeze,
                                            The Spry Framework files that are in the Dreamweaver configuration directory are only used when Dreamweaver copies the dependent files to the user's site. If you've manually installed the Spry 1.5 files into Dreamweaver's configuration directory, all of the features within Dreamweaver should still work, and all of the Code that Dreamweaver produces and inserts into your page should work without any modification with the Spry 1.5 files.
                                            --== Kin ==--
                                            • 19. Re: Spry 1.5 and dw cs3
                                              Dear Kinblas,
                                              but after manually exchanging the spry files in the dreamweaver directory it's still not possible to use all new features of the spry framework. for instance you can set a column to be a string, number, date and image link in Dreamweaver. With Spry 1.5 it would make sense if you could set it to html for instance too.
                                              Then new effects or new widgets are not supported from within dreamweaver, you can just use the same features as in spry 1.4.
                                              How difficult is it to produce an installer and update Dreamweaver from time to time so your customers are able to use the full features of any new spry version?
                                              It would highly speed up the acceptance of this framework, i consider it to be one of the best ajax frameworks there are, but if you have to turn to handcoding, why not use scriptacoulus instead? Think it over, you have got dreamweaver wich is the best WYSWYG Web Development Environment and you have a great Ajax framework. With CS3 both been perfectly connected. Without an official adobe update installer your customers have to face unnecessary obstacles.
                                              Sascha
                                              • 20. Re: Spry 1.5 and dw cs3
                                                Newsgroup_User Community Member
                                                "SaschaSchwartz" <webforumsuser@macromedia.com> wrote in message
                                                news:f33nvk$9d7$1@forums.macromedia.com...
                                                > to be
                                                Simply because Scriptacoulus has nothing that can compare to Spry's dataset
                                                and data centric functionality :-)))
                                                YUI is slowly introducing something that moves in that direction, but it's
                                                far behind. This is an area where Spry is well ahead of the rest of the pack
                                                (when it comes to effects or widgets instead you can find plenty of
                                                excellent alternatives).
                                                Don't get me wrong, I see and understand your point, I just want to let you
                                                know that there are many people who are using Spry outside of DW, they are
                                                more than happy to hand code and are choosing Spry for its unique features
                                                set. As you can imagine, those people see things in a different perspective.
                                                Massimo Foti, web-programmer for hire
                                                Tools for ColdFusion and Dreamweaver developers:
                                                http://www.massimocorner.com
                                                • 21. Spry 1.5 and dw cs3
                                                  Just to save some people time...as long as your installation of dreamweaver is in c:\program files, copy this .bat file into the spry_p1_5_051707 directory that is unzipped on your hard drive, drop to a command prompt and type in updatespry.bat and it will copy all of the necessary files over to the correct directories.
                                                  PS: Copy the entire Spry directory off to another location before you run it so you have a backup copy of the 1.4 files. Since I cannnot seem to attach files, just copy and paste the following lines into an editor and save it off as a .bat file.
                                                  copy includes\SpryData.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Data\"
                                                  copy includes\SpryXML.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Data\"
                                                  copy includes\xpath.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Data\"
                                                  copy includes\SpryEffects.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Effects\"
                                                  copy widgets\accordion\SpryAccordion.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\Accordion\"
                                                  copy widgets\collapsiblepanel\SpryCollapsiblePanel.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\CollapsiblePanel\"
                                                  copy widgets\collapsiblepanel\SpryCollapsiblePanel.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\CollapsiblePanel\"
                                                  copy widgets\menubar\SpryMenuBar.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\MenuBar\"
                                                  copy widgets\menubar\SpryMenuBarHorizontal.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\MenuBar\"
                                                  copy widgets\menubar\SpryMenuBarVertical.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\MenuBar\"
                                                  copy widgets\tabbedpanels\SpryTabbedPanels.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\TabbedPanels\"
                                                  copy widgets\tabbedpanels\SpryTabbedPanels.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\TabbedPanels\"
                                                  copy widgets\checkboxvalidation\SpryValidationCheckbox.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\ValidationCheckbox\"
                                                  copy widgets\checkboxvalidation\SpryValidationCheckbox.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\ValidationCheckbox\"
                                                  copy widgets\selectvalidation\SpryValidationSelect.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\ValidationSelect\"
                                                  copy widgets\selectvalidation\SpryValidationSelect.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\ValidationSelect\"
                                                  copy widgets\textareavalidation\SpryValidationTextarea.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\ValidationTextarea\"
                                                  copy widgets\textareavalidation\SpryValidationTextarea.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\ValidationTextarea\"
                                                  copy widgets\textfieldvalidation\SpryValidationTextField.css "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\ValidationTextField\"
                                                  copy widgets\textfieldvalidation\SpryValidationTextField.js "C:\program Files\adobe\Adobe Dreamweaver CS3\Configuration\Shared\Spry\Widgets\ValidationTextField\"
                                                  • 22. Re: Spry 1.5 and dw cs3
                                                    Günter Schenk CommunityMVP
                                                    Hi Skeeze,
                                                    thanks very much for the .bat, it worked fine !! I just wonder if not all files from the "includes" folder should be copied to the "Shared\Spry\Data" directory to make it a complete installation ?
                                                    However, if anyone wants that, I can provide a .bat for german windows systems where it´s all by default installed in "C:\Programme\Adobe\Adobe Dreamweaver CS3\..." -- search/replace would also do ;-)
                                                    • 23. Spry 1.5 and dw cs3
                                                      ccptechs_mvo Community Member
                                                      Adobe -
                                                      Your Spry development is great, but you really should have a Dreamweaver update/installer for each new revision of the framework.
                                                      Initially, the majority of users are ALMOST ALL DREAMWEAVER users. This might change as it gains more universal acceptance, but you are really biting the hand that feeds you by not issuing an auto-update installer for each revision.
                                                      Not to mention that your Dreamweaver Support Team will waste many unnecessary hours on the phone/chat/email with customers who have tried to make the modifications by hand.
                                                      Sorry if I sound harsh, but you guys are selling cheeseburgers without the CHEESE and it really needs to stop!
                                                      =o)
                                                      • 24. Re: Spry 1.5 and dw cs3
                                                        jmbishop Community Member
                                                        This blog post from Don Booth talks about Adobe's plans to develope an easier way to update the Spry framework and files.
                                                        http://blogs.adobe.com/spryteam/
                                                        J Bishop
                                                        • 25. Re: Spry 1.5 and dw cs3
                                                          Minding Community Member
                                                          After following the instructions for copying v1.5 into the Configuration folder, to be safe I renamed the files in my SpryAssets folder to indicate they are v1.4. Now, if there is to be havoc from using to v1.5, let the havoc begin!
                                                          • 26. Re: Spry 1.5 and dw cs3
                                                            Interloper
                                                            So where can I get this update? I too am pretty disappointed with just how complicated this process is. I would have thought you could easily insert dwop down menus straight into the page and customise them easily. Project 7 products do a much better job than this - I guess that's teh kind of interface and ease of use I thought spry would offer.
                                                            • 27. Re: Spry 1.5 and dw cs3
                                                              I found it at http://labs.adobe.com/technologies/spry/ in the 'Download and
                                                              Discuss area'. It's got all the Read Me files as to what's changed but not
                                                              an updated Dreawmweaver CS3 help file so jkeep them handy. No doubt
                                                              Dreamweaver's next upgrade will include this.
                                                              On 26/6/07 7:40 am, in article f5qcd9$t02$1@forums.macromedia.com,
                                                              > products
                                                              • 28. Re: Spry 1.5 and dw cs3
        Garry Bradley wrote:
        > No doubt
        Maybe, maybe not. There's a detailed explanation of the relationship
        between Spry and Dreamweaver releases here:
        http://blogs.adobe.com/spryteam/2007/06/post.html
        David Powers, Adobe Community Expert
        Author, "Foundation PHP for Dreamweaver 8" (friends of ED)
        Author, "PHP Solutions" (friends of ED)
        http://foundationphp.com/
        • 29. Re: Spry 1.5 and dw cs3
        S_Leonard Community Member
        Just a quick note that you have included the SpryAccordion.css file twice in your batch of files to be copied, one of those should be SpryAccordion.js
        • 30. Re: Spry 1.5 and dw cs3
        "David Powers" <david@example.com> wrote in message
        news:f5u47s$kul$2@forums.macromedia.com...
        >> No doubt
        Making any updated Spry files a lot easier to integrate into DW would be a
        good start
        Having to do it all manually and then find that something doesn't work as it
        did with the original files is an absolutey nightmare !
        Nadia
        Adobe® Community Expert : Dreamweaver
        • 31. Re: Spry 1.5 and dw cs3
        Donald Booth Community Member
        Ok ok! ;)
        I have an extension that I have been developing, keeping up the code hints for DW and Spry. It also includes the latest 1.5 files.
        We didn't release it because we are working on a better solution.
        But this will help until that other solution is ready.
        http://www.dbooth.net/spry/spry_mxp.htm
        This simply updates the config folder with the latest files and updates code hinting and coloring.
        As the page says, this is NOT an official Adobe release and hasn't been through the testing wringer, but it should work just fine. The new code hints are quite helpful.
        I hope this helps with the pain.
        Don
        • 32. Re: Spry 1.5 and dw cs3
        > good start
        I agree. I have made no secret of my dissatisfaction with the mismatch
        between the Dreamweaver and Spry release cycles. Quite frankly, it makes
        Dreamweaver CS3 look like a paid-for beta. Sorry, Adobe, but this is
        like the CS3 installer - something that should not have been imposed on
        paying customers.
        However, Don has made an "officially unofficial" extension available
        that should help move things forward in a positive way:
        • 33. Re: Spry 1.5 and dw cs3
        "Donald Booth" <webforumsuser@macromedia.com> wrote in message
        news:f60l1t$rrh$1@forums.macromedia.com...
        > Ok ok! ;)
        > for
        Don,
        how is this supposed to work. I see it is a command, but it doesn't appear
        in the command menu once installed.
        Nadia
        • 34. Re: Spry 1.5 and dw cs3
        All it does is copy the new Spry files to the user config folder.
        Next time you use a Spry thing that needs a Spry asset, it will be copied to your local root folder, but only if it is not in the SpryAssets folder already.
        If you need to copy over the new files for the accordion, for example, you will have to remove the existing SpryAccordion files from your site. Then add an accordion to a new page.
        The new files will be copied over.
        There is no menu item for the extension.
        So it's not super helpful, but at least you don't have to mess with the config folder.
        You also get code hinting for the latest stuff. You will see it when you type 'var ds3 = new Spry.' and the new data sets will hint.
        The thing we are working on will help this workflow quite a bit...
        Don
        • 35. Re: Spry 1.5 and dw cs3
        Thanks Don,
        the explanation is now clear ;-)
        Nadia
        CSS Templates |Tutorials |SEO Articles
        http://www.DreamweaverResources.com
        ~ Customisation Service Available ~
        http://www.csstemplates.com.au
        Spry Widget Examples
        http://www.dreamweaverresources.com/spry-widgets/
        > to
        > already.
        > add
        > config
        > folder.
        > type
        > Thanks,
        > Don
        • 36. Re: Spry 1.5 and dw cs3
        Greetings,
        May I ask for your help to send me an e-mail of the Accordion spry designtime folder, because I've accidentally deleted its designtime when I upgraded from spry widget 1.4 to 1.5 :( Or may I ask where I can download it?
        I would appreciate your help, it'll be very big for me. Thanks!
        Sincerely,
        Van
        • 37. Re: Spry 1.5 and dw cs3
        dehelias Community Member
        I do not know how complicated it might be (the Adobe gang would need to answer it), but rather than using an extension to update the Spry component of DWCS3 from 1.4 to 1.5, would it be better to use the Adobe Update feature that is built into CS3?
        I ask as an extension makes sense if it could add Spry to earlier versions of DW, but if it cannot then the Adobe Update function might be better as Spry is an actual shipped part of DWCS3. That way it could be directly integrated into DW via a batch/patch file (or whatever method Adobe chose). Additional updates to Spry could be accomplished the same way. If it were done that way, however, some form of notice would be necessary to alert people to what it was doing and some form of readme should be included.
        Just an idea.
        Skip Keats
        • 38. Re: Spry 1.5 and dw cs3
        TommyLogic Community Member
        quote:
        Originally posted by: Donald Booth
        Ok ok! ;)
        Don
        Don, thank you for posting this extension.
        Have you figured out any way to get these new widgets into the menu bar yet?
        Can I add them to the fovorites panel somehow?
        Thanks again,
        Tommy
        • 39. Re: Spry 1.5 and dw cs3
        To reply to the last 2 respondents,
        I made the extension because we could just do it and release it by ourselves. The Adobe Update process has more overhead and it would take longer to get out. Plus, using an extension will allow us to include it in the Spry zip.
        But we might end up using the AU because, well, that's what it is for.
        And for the last poster, I mentioned that this mxp does not add any new features to DW. It simply updates the Spry js files that get copied over to the site.
        Don
        1 2 Previous Next
