11 Replies Latest reply: Jun 27, 2014 11:47 AM by Cozmo2 RSS
    Save Data in Report to Use later
    Cozmo2 Community Member
      I have several names to report I need to combine data from several records of the same type with different codes. Not all names have the same codes. I want to report the data on one line. Is there a way to save date to be used later in the report?
      For Example:
      Name              Code   Start Date        Code Transfer Date  Code              Promote Date
      Sue
      SD
      01/15/2000
      TD
      01/15/2005
      Mitch
      SD
      01/15/2004
      Sam
      SD
      01/15/2003
      PD
      01/15/2006
        • 1. Re: Save Data in Report to Use later
          Eddie Lotter Community Member
          Firstly, what are you using to create the report? cfreport, cfdocument or what?
          • 2. Re: Save Data in Report to Use later
            I am using CF10 Report Builder.
            • 3. Re: Save Data in Report to Use later
              Okay, that limits your options somewhat.
              Now, your example isn't clear what you want to do. What data in the three different records do you want to display on one line in the report?
              • 4. Re: Save Data in Report to Use later
                Using the three records above I want the report to print (I'm using the Name Group Footer):
                NameStart DateTransfer DatePromote Date
                Sue
                01/15/2000
                01/15/2005
                Mitch
                01/15/2004
                Sam
                01/15/2003
                01/15/2006
                • 5. Re: Save Data in Report to Use later
                  From this reply it seems that by "one line" you mean "one report band".
                  The best way to show multiple records in a non-detail report band (like your Name Group Footer) is to use a sub-report.
                  • 6. Re: Save Data in Report to Use later
                    Thanks for your help and great suggestion!
                    • 7. Re: Save Data in Report to Use later
                      You're welcome.
                      • 8. Re: Save Data in Report to Use later
                        I finally created the sub-report. I am getting the correct output but it is not printing the data across the band. I created calculated fields to only show if the appchk_cod matched the column heading.
                        How can I save the dates for the different appchk_cod and print them in the same band? I want the report to look like:
                                                 Disposition     Filing     FAFSA       Award              Award         Jump Start     Housing             Housing
        FAFSA    Date        Letter Sent     Letter Rec'd        Date      Contract Rec'd     Deposit Rec'd
                        Student Name     Accepted                    05/15/2014                          3/14/2014       06/14/2014     06/14/2014          06/14/2014
                        It looks like this:
                        • 9. Re: Save Data in Report to Use later
                          I think I now have a better idea of what you are trying to accomplish.
                          You don't need a sub-report to get each person's dates on the same line. It is best to do that in your query, for example:
                          select table_name.UserName, dtFafsa.FafsaDate, dtLetterSent.LetterSentDate, dtLetterReceived.LetterReceivedDate
                          from table_name left outer join
                          (select userID, FafsaDate from table_name as table_name_fafsa where appchk_cod = 'FF') as dtFafsa on table_name.userID = dtFafsa.userID
                          left outer join
                          (select userID, LetterSentDate from table_name as table_name_LetterSent where appchk_cod = 'AS') as dtLetterSent on table_name.userID = dtLetterSent.userID
                          left outer join
                          (select userID, LetterReceivedDate from table_name as table_name_LetterReceived where appchk_cod = 'AR') as dtLetterReceived on table_name.userID = dtLetterReceived.userID
                          This is obviously not syntax checked, but it illustrates the concept.
                          Each derived table returns the date of each code. You will need a derived table for every code you want to report on.
                          • 10. Re: Save Data in Report to Use later
                            I created part of the query and tested it. It ran great, however, when I try to open my report I get:
                            500 - Internal server error.
                            There is a problem with the resource you are looking for, and it cannot be displayed.
                            My query is below. Why won't the report work? Right now the only data I display is the Name and FAFSA-Date
                            SELECT name.soc_sec, name.last_name, name.first_name, name.nickname, name.mi, name.camp_cod, dtFAFSA.comp_dt as FAFSA_Date
                            FROM Name
                            LEFT OUTER JOIN
                            (SELECT soc_sec, comp_dt FROM nmappchk as nmappchk_FAFSA WHERE appchk_cod = 'FF') as dtFAFSA
                            on name.soc_sec = dtFAFSA.soc_sec
                            • 11. Re: Save Data in Report to Use later
                              Is working now. I found some left over code on my report!
                              Thanks for your help.
