I am trying to install the latest flash player update but it just freezes when I run the installer.
Not sure if this is downloading the update per say, but I left it running for over an hour and nothing happened, just a spinning pinwheel.
I am on a Mac, OSX 10.9.3 Mavericks, and trying to install the latest flash player update. I added a screenshot below...
Also where should I have posted this?
My thread in the apple support forum: Why is my flash update freezing?...: Apple Support Communities
My suggestion is to use the DMG installer http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player_osx.dmg
Thanks a lot. I had the same problem as the OP. Your solution worked.
Alfred
Pat Willener:
Thanks for that link.—it worked for me. I hope someone in Adobe's Tech Support is monitoring these forums. There is clearly something wrong with the other update installer. I pasted some log info in my other reply about having problems with the installer.
Pat Willener -
Thank you, that direct link worked for me as well (Mavericks 10.9.3), I appreciate your help.
Harry
[topic moved to the Installing Flash Player forum]
There must be a problem with the latest Flash Installer, because I haven't had issues with the installers before this version. I'm getting the spinning beach ball after authorizing the installation on my MBP.
I'm seeing these log files in Console:
Install Adobe Flash Player_2014-06-11-154629_<my computer name>.hang
Command: Install Adobe Flash Player
Path: /Users/USER/Desktop/Install Adobe Flash Player.app/Contents/MacOS/Install Adobe Flash Player
Process: Install Adobe Flash Player [8598]
16 ??? (Install Adobe Flash Player + 4117) [0x2015]
16 ??? (Install Adobe Flash Player + 5283) [0x24a3]
16 ??? (Install Adobe Flash Player + 227337) [0x38809]
16 ??? (Install Adobe Flash Player + 211532) [0x34a4c]
16 ??? (Install Adobe Flash Player + 23696) [0x6c90]
16 ??? (Install Adobe Flash Player + 82988) [0x1542c]
16 ??? (Install Adobe Flash Player + 506316) [0x7c9cc]
16 ??? (Install Adobe Flash Player + 448490) [0x6e7ea]
16 ??? (Install Adobe Flash Player + 445751) [0x6dd37]
16 ??? (Install Adobe Flash Player + 423904) [0x687e0]
0x1000 - 0xa2ff7 com.solidstatenetworks.host 2.0.2.7 (2.0.2.7) <EC21308F-D578-3FFE-B9A2-7227806047BE> /Users/USER/Desktop/Install Adobe Flash Player.app/Contents/MacOS/Install Adobe Flash Player
and this:
6/11/14 15:23:38.711 SIMBL Agent[535]: Install Adobe Flash Player started
6/11/14 15:23:38.712 SIMBL Agent[2416]: warning: failed to get scripting definition from /Users/michael_durio1/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
6/11/14 15:23:38.714 SIMBL Agent[535]: warning: failed to get scripting definition from /Users/michael_durio1/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
6/11/14 15:23:38.733 Install Adobe Flash Player[5808]: 'ascr'/'gdut' event received from process (pid=2416 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
6/11/14 15:23:38.733 Install Adobe Flash Player[5808]: 'ascr'/'gdut' event blocked because this process doesn't export scripting additions
6/11/14 15:23:38.734 Install Adobe Flash Player[5808]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x56056, pid=2416, because it is not entitled to send an AppleEvent to this process.
6/11/14 15:23:38.734 Install Adobe Flash Player[5808]: 'ascr'/'gdut' event received from process (pid=535 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
6/11/14 15:23:38.734 Install Adobe Flash Player[5808]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x28028, pid=535, because it is not entitled to send an AppleEvent to this process.
6/11/14 15:27:36.000 kernel[0]: process Install Adobe Fl[5808] caught causing excessive wakeups. Observed wakeups rate (per sec): 189; Maximum permitted wakeups rate (per sec): 150; Observation period: 300 seconds; Task lifetime number of wakeups: 45014
6/11/14 15:27:37.729 spindump[6341]: Saved wakeups_resource.spin report for Install Adobe Flash Player version 2.0.2.7 (2.0.2.7) to /Library/Logs/DiagnosticReports/Install Adobe Flash Player_2014-06-11-152737_<my computer name>.wakeups_resource.spin
6/11/14 15:40:49.548 SIMBL Agent[535]: Install Adobe Flash Player started
6/11/14 15:40:49.549 SIMBL Agent[2416]: warning: failed to get scripting definition from /Users/michael_durio1/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
6/11/14 15:40:49.550 SIMBL Agent[535]: warning: failed to get scripting definition from /Users/michael_durio1/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
6/11/14 15:40:49.569 Install Adobe Flash Player[8146]: 'ascr'/'gdut' event received from process (pid=2416 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
6/11/14 15:40:49.569 Install Adobe Flash Player[8146]: 'ascr'/'gdut' event blocked because this process doesn't export scripting additions
6/11/14 15:40:49.569 Install Adobe Flash Player[8146]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x56056, pid=2416, because it is not entitled to send an AppleEvent to this process.
6/11/14 15:40:49.570 Install Adobe Flash Player[8146]: 'ascr'/'gdut' event received from process (pid=535 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
6/11/14 15:40:49.570 Install Adobe Flash Player[8146]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x28028, pid=535, because it is not entitled to send an AppleEvent to this process.
6/11/14 15:43:58.725 SIMBL Agent[535]: Install Adobe Flash Player started
6/11/14 15:43:58.727 SIMBL Agent[2416]: warning: failed to get scripting definition from /Users/<my user account>/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
6/11/14 15:43:58.727 SIMBL Agent[535]: warning: failed to get scripting definition from /Users/<my user account>/Desktop/Install Adobe Flash Player.app; it may not be scriptable.
6/11/14 15:43:58.755 Install Adobe Flash Player[8598]: 'ascr'/'gdut' event received from process (pid=2416 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
6/11/14 15:43:58.755 Install Adobe Flash Player[8598]: 'ascr'/'gdut' event blocked because this process doesn't export scripting additions
6/11/14 15:43:58.755 Install Adobe Flash Player[8598]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x56056, pid=2416, because it is not entitled to send an AppleEvent to this process.
6/11/14 15:43:58.756 Install Adobe Flash Player[8598]: 'ascr'/'gdut' event received from process (pid=535 r/e uid=501/501 gid=20/20) with different credentials than (euid=0 egid=20)
6/11/14 15:43:58.756 Install Adobe Flash Player[8598]: AppleEvents/sandbox: Returning errAEPrivilegeError/-10004 and denying dispatch of event ascr/gdut from process 'SIMBL Agent'/0x0-0x28028, pid=535, because it is not entitled to send an AppleEvent to this process.
6/11/14 15:46:29.826 spindump[8950]: Saved hang report for Install Adobe Flash Player version 2.0.2.7 (2.0.2.7) to /Library/Logs/DiagnosticReports/Install Adobe Flash Player_2014-06-11-154629_<my computer name>.hang
I'm wondering why SIMBL appears to be involved in this process, unless that message is a red herring. I have EasySIMBL version 1.4 installed.
I had the same issues... I posted to twitter, under the handle @djkinkle , about it with screen shots.
Also, I'm going to post the link to the download located in this forum to twitter.
Thanks a lot that solved it!
