0 Replies Latest reply: Jun 11, 2014 11:13 PM by alan_lindsay RSS
    CF11 Actionscript 3 - I'm migratiing from AS2 and can't use REMOTING, so how to use cfc's and process their results?
    alan_lindsay Community Member
      The CF11 integration notes describe how to do use Flash Remoting. I use that in my AS2 code and it works fine. I'm trying to migrate to AS3 where there is no Remoting. I have done the following:
      import flash.net.*;
      import flash.events.*;
      var CFCService = new NetConnection()
      CFCService.objectEncoding = 0;
      CFCService.connect("http://localhost:8500/flashservices/gateway/")
      var responder2 = new Responder(getActiveUsers_Result, onFault);
      CFCService.call("cfc.SyslockComponents.getActiveUsers", responder2);
      stop();
      function getActiveUsers_Result(result:Object):void
          trace("getActiveUsers Result Status: " + result.STATUS);
          for (var property:String in result)
              trace(property +" : " +result[property]);
      The OUTPUT of my program shows the contents of the STRUCT returned by the CFC:
      getActiveUsers Result Status: ALLOK  <<<<<< the CFC completed successfully
      RECCOUNT : 1  <<<<<<<< There was one record select by query
      DETAILS : [object Object]  /<<<<<< this contains the query results
      STATUS : ALLOK
      I don't know how to process DETAILS because RECORDSET is not available in AS3.
