Is there any idea when SCUP updates for Flash 14 (or Reader 11.0.07) will be available?
These should be available now. Are you not seeing version 14 on this page?
Chris you are correct, thank you for your response.
After some digging it appears that SCUP itself was the issue. Although at a glance it looked as if there were no new updates after digging into some logs I found
"Error .5 UtilClassFactory.CreateInstance Received TargetInvocationException from ClassFactory call: Access is denied"
I was able to download updates as soon as I rand SCUP with elevated privilege. This was not previously the case but I'm all set now.
