I'm trying to evalute whether a user is uploading an MS Word
file with spaces in the filename. We cannot have spaces in
filenames on our Internet site. So, basically, on the form page
there is a field with a browse box for user to select their file.
It's is passed to the action page; here's the code.
I've used the same <cfif> statement on a bare bones
page & it does work but for some reason it is not working on
this page. I'm wondering if there's code on this page preventing it
from being evaluted.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0
Transitional//EN">
<html>
<head>
<title>Human Resources Job Bank Form
Action</title>
</head>
<body>
<!-- Check for spaces in filename -->
<cfif form.positionfile CONTAINS " ">
The document you attached to this position contains spaces in
the filename. We cannot post documents containing spaces or special
characters on the Internet.<br><br>
<b>How to fix the problem
—</b><br><br>
<OL>
<LI>Please rename the original file without using
spaces or punctuation. <br><br>The following characters
are approved for file naming on the Web.
<ul type="square">
<li>Letters A-Z and a-z
<li>Numerals 0-9
<li>Dashes ( - )
<li>Underscores ( _ )
</ul>
<br>
<LI>Use your web browser's <b>Back</b>
button to return to <b>Post a Position in the Job
Bank</b> and reattach the position using the "Upload
Document" box.<br><br>
<LI>Resubmit the position using a compatible filename.
<BR><BR>
</OL><BR>
<cfelse>
<!--- capture the autonumber position id for use in the
uploads table --->
<cflock name="#CreateUUID()#" timeout="20">
<cftransaction>
<!--- Insert the position info into the main positions
table --->
<CFQUERY NAME="Insertposition"
DATASOURCE="#Application.DSN#">
Insert into positions
(title, medcenterID, otherlocation, areaID, carelineID,
grade, emailID, opendate, closedate)
VALUES
('#FORM.title#','#FORM.medcenterid#','#FORM.otherlocation#','#FORM.areaID#','#FORM.carelineid#','#FORM.grade#','#FORM.emailID#','#FORM.opendate#','#FORM.closedate#')
</CFQUERY>
<cfquery DATASOURCE="#Application.DSN#"
name="getLastID">
SELECT MAX(positionID) as lastID
FROM positions
</cfquery>
</cftransaction>
</cflock>
<!--- Confirm to the user that the position was
successfully added, allow them to add another or see the master
list --->
<cfoutput>#DateFormat(createodbcdate(Now()),'mm/dd/yyyy')#
<br>
Position ID #getlastid.lastid#: #Form.Title#</cfoutput>
has been added to the HR Job Bank.<br><br>
<!--- upload the file to the directory and only accept
word docs --->
<cffile action="UPLOAD" filefield="positionfile"
destination="#application.uploaddirectory#"
nameconflict="MAKEUNIQUE">
<!--- Fill in the uploads table with the name and path for
the uploaded file --->
<CFQUERY NAME="CreateDocumentRecord"
INSERT INTO Uploads (positionID, Date_Published, File_Name,
Upload_Path)
VALUES
('#VAL(getlastid.lastid)#',#createodbcdate(Now())#,'#FILE.ClientFile#','#FILE.ServerFile#')
</CFQUERY>
</cfif>
<!--- Grab Medical Center Name --->
<CFQUERY name="getmedicalcenter"
SELECT medcenterID, medcenter_name
FROM location
WHERE medcenterID = #form.medcenterID#
</CFQUERY>
<!--- Grab Area Name --->
<CFQUERY name="getarea" DATASOURCE="#Application.DSN#">
SELECT areaID, area_name
FROM areaofconsideration
WHERE areaID = #form.areaID#
</CFQUERY>
<!--- Grab Care Line Name--->
<CFQUERY name="getcareline"
SELECT carelineID, careline_name
FROM carelines
WHERE carelineID = #form.carelineID#
</CFQUERY>
</cfif>
</body>
</html>
