I have develop a form which involves two parsons to fill in.
There are some required fields on the form and the issue I have is when
I try to send the form directly from Acrobat (File>Send File) I am getting the message
that some fields are required.
How I can avoid this message? The requiree fields are for the second user to fill in no for the first user.
Thank you
Total Likes
Mhmm by experience I would say you have 1 or more field(s) which are required and hidden.
If any field is required and cannot be filled because it is hidden or invisible it will send a message saying that some required field(s) are not filled in.
To avoid such error, you would have to not set field(s) such as required.
If you want to have validation to your likings you could use a method I've developed for xfa forms with Livecycle.
There's plenty of explanation + a form with exemples.
Re: Resources for from design - best practices for layout?
With this practice you should be able to work with forms the way you want.
Another way without using the method above would be changing the required fields as the form follows. When a required field becomes hidden you should remove it's required property and set it to optional.
Hope this will work.
Total Likes
