Sending a chart via email
Guest
Aug 13, 2007 Aug 13, 2007
Would anyone know if it is possible to generate a cfchart in an email? I tried and it would not show in the email. I tried with gmail and with MS Outlook.
Below id the code I used:
<cfmail to="abc@abc.com" from="abc@abc.com" subject="chart test" type="HTML">
email start
<cfchart
xAxisTitle="Day"
yAxisTitle="Visitors"
font="Arial"
gridlines=6
showXGridlines="yes"
showYGridlines="yes"
showborder="yes"
show3d="yes"
chartHeight = "500"
chartWidth = "700"
XAxisType="date"
<cfchartseries type="bar" seriesColor="red" paintStyle="plain">
<cfchartdata item="1" value="100">
<cfchartdata item="2" value="200">
<cfchartdata item="3" value="300">
<cfchartdata item="4" value="250">
</cfchartseries>
</cfchart>
email end
</cfmail>
Advanced techniques
506
shloime11 wrote:
> Hi,
no, not possible.
but you could:
- first generate a jpeg-format chart and, using the NAME attribute of
<cfchart> tag assign it to a variable instead of displaying the chart
- use <cffile action="write" output="#yourcfchartvariablenamehere#"
file="fullpathtoyourfilehere" addnewline="no"> to save it as a jpeg image,
- and then attach that file to the email.
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
Aug 14, 2007 Aug 14, 2007
You can also embed it in the email using a bit of MIME trickery, although this is far more complicated, using the following steps:
1. Generate the chart and give it a name so it is stored in a variable.
2. Generate a UUID that you will use as a CID for the image in the email.
3. Save the image to a temporary directory using the UUID as the filename.
4. Write the HTML contents of the email and place an <img src=" the UUID"> where you want the chart to appear.
5. Attach the file to the email
6. Delete the temp file
Something like:
Documentation
